News
355 F1 ignition start up noise
Discussion in 'Technical Q&A' started by ferrariwalla355, Nov 8, 2018.
  1. ferrariwalla355
    Sep 4, 2004
    40
    Austin, TX
    In my 1999 Berlinetta, when I turn the key, there’s a humming noise which sounds like something is getting filled up. Used to take about 15 seconds, now it’s a little over 20 seconds. Does this sound like a developing problem, as in the F1 pump, or is it something else? If so, where and how do I diagnose it? I’m not sensing any issues with F1 pedal shifting, though.
    Thank you all for your help.
  2. Dave rocks
    Dave rocks F1 World Champ
    15,969
    Orchard Park, NY
    Dave Lelonek
    It's the F1 pump priming. Normal.
    BOKE likes this.
  3. taz355
    taz355 F1 Rookie
    Silver Subscribed Owner
    Feb 18, 2008
    4,696
    Indio Ca/ Alberta
    Grant
    How many flashes of the f1 icon on the dash before pump shuts off
  4. taz355
    taz355 F1 Rookie
    Feb 18, 2008
    4,696
    Indio Ca/ Alberta
    Grant
    Transmission icon rather than F1. Do not want to confuse you
  5. taz355
    taz355 F1 Rookie
    Feb 18, 2008
    4,696
    Indio Ca/ Alberta
    Grant
    If. You really want. To learn about your Car you. Should read the manual on the f1.
  6. Qavion
    Qavion Formula 3
    Feb 20, 2015
    1,759
    Ian Riddell
    I had a quick look, but couldn't find any pump times, Grant.
    What time frame are we talking about here? In a matter of months? Since new?
  7. taz355
    taz355 F1 Rookie
    Feb 18, 2008
    4,696
    Indio Ca/ Alberta
    Grant
    There isnt in the manuals
    I would say normal pump times from my experi nce are below 20 seconds.
    I usually have not stop watched them but rather counted the flashes of the tranny icon.
    This is not all ways accurate because sometimes you get a definate outlier
    Mine was flashing (from memory) 13 times or less for years with no f1 troubles.
    Once it got over 15 i started to have motor problems which were the motor getting hot and not working. This usually happen while stopped or parked likely due to heat soak once no more air was flowing. My temp solution was to pour water on the motor and then it worked and got me home.
    Once I replaced the motor only it went back down to about 7 flashes.
    Keep in mind a worn accumulator will cause a similar issue with times d likely cause a motor failure even faster.
    Qavion likes this.
  8. taz355
    taz355 F1 Rookie
    Feb 18, 2008
    4,696
    Indio Ca/ Alberta
    Grant
    In this instance for the op I would do what I did and check the current running through the motor and monitor the amps.
    His problem could easily be an accumulator if the change has happned over a very short time.
    Others can chime in but for motors my experience is generally they slowly get worse, but an accumulator problem will very quickly show up in increased pump times.
    Again just my experience
    Qavion likes this.
