355 F1 pump and motor fix | FerrariChat
Discussion in '348/355' started by taz355, Apr 2, 2017.
  1. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    #1 taz355, Apr 2, 2017
    I should clarify that this is an electric motor for the F1 system not the pump or accumulator.
    I recently purchased an electric motor from juri, the same guy who sells the uograded relay for our F1 systems.
    This motor is plug and play with a few minor mods I am sure he will adjust or you can adjust as I did
    The motor was ins talled in about 1.5 hrs and seems to provide the same function as the original.
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    #2 taz355, Apr 2, 2017
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    #3 taz355, Apr 2, 2017
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    #4 taz355, Apr 2, 2017
  5. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    I would just like to thank Yuri for his solution which was basically plug and play.
    The process was
    Remove airbox
    Remove rear wheel and wheel well liner
    Loosen F1 nuts on bracket 2
    Slide F1 unit up and off bracket
    Remove two hex bolts holding in old motor
    Remove motor
    Install a 1/4 inch rubber spacer between rubber mount and F1 unit bottom post
    This lifts the pump and motor assembly about 1/4 inch
    Bolt in new motor with supplied hex bolts
    Reinstall everything
    Took about 1.5 hrs with a few breaks etc.
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    #6 taz355, Apr 2, 2017
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    #7 taz355, Apr 2, 2017
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    Th new motor fits inexactly the same place, no need to re bleed system, the whole system sits 1/4 to 1/2 inch higher. Still uses same heat shield with no adjustments. I feel its the best aftermarket set up.
    Only problem I see is if our old accumulators are starting to go.
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    The motor should turn counter clockwise when hooked up.
  10. phrogs
    phrogs F1 Veteran
    7,130
    Michigan
    Awesome so cost difference vrs hill and a 360 pump?
  11. WATSON
    21,724
    WI
    What is the symptom for a failing accumulator?
  12. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Your pump will prime every 10 seconds.If you open your cap you can watch your ATF go up and down as the pump prime's.
  13. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    If the accumulator is bad - it's not going to hold pressure so yes, the pump will run more often to compensate for the leakage
  14. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    What is the part source and part number for the new motor?
  15. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    I bought it from Juri have no idea and not a sponsor.
    Its an aftermarkey motor that I am sure he bought with no markings and built an adapter plate and delrin adapter for coupling only.
    Sorry Ernie.
  16. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    Mike no one seems to want to post how long a new accumulator will hold pressure.
    If you let car sit, not running how long between cycles of the pump and motor??
    This I would like to know!!
    This way we would know when accumulators are getting bad!,
  17. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    Also if the nitrogen is leaking bad the fluid supposedly gets milky. Third party info.
    Anyone know what the pressure is inside the accumulatorfrom factory for the nitrogen.
    Also can you change the accumulator without the sd3?
    It looks like you could since a bleed port is right there .
  18. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Grant - I will post in a week or so when I get the car out.
    Not sure but it's SD for 355 :)
  19. WATSON
    21,724
    WI
    What is inside the accumulator bottle?
  20. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Grant
    It all depends how long the car sat.With my 360 pump update the next day it would blink 1 or 2 times.If it sits for a week it could take 5 or 6 blinks.
  21. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Mike, Grant is trying to get a baseline from an "as new" system. That is obtainable and has nothing to do with how long the car sat aside from a fully depressurized accumulator.
  22. WATSON
    21,724
    WI
    Never mind. I see it is just a little pressure tank.
    Anyone know what the specs are?
  23. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Sorry i forgot to add that is with a new accumulator.
  24. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    It seems pretty good mine has never been that good from when I got it. Mine used to take about 11 maybe from months left alone 10 plus years ago. The last 5 years about 12 to 13 and after24 hrs likely 11.
    1 hr likely 7 to 9
    2 days back to 13
    This year when motor started to heat soak I checked and was 20. It was failing though.
    I am. Thinking maybe accumulator caused motor to go.
    What about car off let pressurize and time how long before pump kicks in. Engine off
  25. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    Its a bladder with nitrogen on the back side, hydraulic oil on pump side.
    No way to repressurize.
    If I knew pressure I might replace with a refillable one for next time.
    Anyone any facts about that??
