355 F1 will not start | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Cchris0411, Nov 26, 2006.
  1. Motob
    Motob Formula 3
    Nov 11, 2003
    2,389
    Frederick, Maryland
    Brian Brown
    Ok, It's time to figure this one out.
    What do we know? The car ran before the service, so something has been changed during the service that has caused the engine to not run.
    We know the engine has spark, if quick-start spray is sprayed into the intake, the engine will run. In order to have spark the Motronic control unit must have power, ground, speed and phase sensor inputs. If the Motronic control unit has all of the information to generate a spark, then it should also fire the injectors, but it doesn't. What are the possible causes?
    1: No power to the injectors. There is a relay under the passenger footplate that supplies power to the injectors. If you unplug the connector at the fuel injectors, there should be constant 12V power on one pin of each injector connector with the ignition key on. If there is no power, you need to trace the problem back to this relay.
    2: No ground to the injectors. When the Motronic control unit fires the injector, it grounds the other pin on this injector connector. You can purchase a little light (known as a "Noid Light") that will plug into the injector connector in place of the injector, so you can see the injector pulse, or you can just listen for the injector clicking with a mechanic's stethoscope. The Motronic control unit gets its ground from the wiring harness that grounds at the rear of the 1-4 cam cover/head. If this is disconnected/loose, it will cause the injector to not fire.
    Check which symptom you have, and we will go from there.
    What relay did you replace and why did you replace it?
    Brian B.
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    No pulse to the injectors.
    No turn-on signal to the fuel pump relay.
    ...but, you've got spark because the engine turns after spraying starter fluid. That tells me that the Motronic ECUs aren't dead and aren't purposefully disabling the engine (e.g. shutting down banks).
    The obvious remaining single cause of both "no injector pulse" and "no fuel pump relay turn-on signal" would be the fuel pump inertia switch (and they do fail).
  3. Cchris0411
    Cchris0411 Rookie
    Jul 5, 2005
    46
    Naples, FL
    Christopher
    Thank you for the reply, I have no power to any of the injectors, all relays under the kick panel check out as ok. Could you tellme more about the fuel pump inertia switch.
  4. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    http://www.rockauto.com/catalog/x,carcode,1104040,parttype,10756
    That bad boy stops your fuel pump if you are in an accident that kills the motor.
  5. Cchris0411
    Cchris0411 Rookie
    Jul 5, 2005
    46
    Naples, FL
    Christopher
    Where exactly is this switch located?
  6. Cchris0411
    Cchris0411 Rookie
    Jul 5, 2005
    46
    Naples, FL
    Christopher
  7. kirill
    kirill Formula Junior
    Jul 8, 2004
    584
    Illinois
    Kirill
    How old is GAS ? It starts to decompose after 3 months if you didn't add Stabil to it.
  8. 62 250 GTO
    62 250 GTO F1 Veteran
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    That's BS a car will run on gas over a year old easily. It may stumble a bit on start up but once it's running and warming up, it'll be fine.
  9. Cchris0411
    Cchris0411 Rookie
    Jul 5, 2005
    46
    Naples, FL
    Christopher
    The gas is all new.
    The issue here is simple. No injector pulse and no fuel pump acivation.
    All fuses and relays are working.
  10. GerryD
    GerryD Formula 3
    May 5, 2010
    2,446
    North of TO
    Guido
    Was reading to find the eventual fix for this but then the thread ended with no result. I know this is an old thread but would be nice to know what was wrong as im having a problem with no injector pulse as well.
  11. Qavion
    Qavion F1 World Champ
    14,531
    Ian Riddell
    Is that the only symptom?
    So you have cranking, you have fuel pressure (fuel pump is running) and you have spark?
    FWIW, the 355 does not have an inertia switch. These first appeared on the 360 and V12's.
  12. tbakowsky
    Sep 18, 2002
    20,038
    The Cold North
    Tom
    Seem like an immobilizer problem.
  13. Qavion
    14,531
    Ian Riddell
    F1?
    Motronic 5.2 (with immobiliser)?
  14. GerryD
    GerryD Formula 3
    May 5, 2010
    2,446
    North of TO
    Guido
    2.7 , no immobilizer. New fuel pump, its not the crank position sensors or the relays and there is spark.
    Qavion likes this.
  15. Qavion
    14,531
    Ian Riddell
    #40 Qavion, Jul 12, 2025
    Do you have 12 volts at the injectors with the key on?
    If you have, then it's an ECU trigger issue, not a power issue.
    (EDIT: is it one bank or both?)
  16. Qavion
    14,531
    Ian Riddell
    If injector relays O and L are working, than you should have power going to the injectors.
    Relay O and L should also illuminate the CEL/SDL lights on startup.
    Relay O and L also send power to the coils of the respective fuel pump relays (P & M). The pump relays also provide power to the O2 heaters.
    Relay O and L should send power to things like the MAF, Cat ECU and Idle Speed Regulators.
    I'm told you don't need cranking to get the pumps to work (like you do on the 5.2).
  17. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,673
    San Carlos, CA
    Mitchell Le
    No Immo, two ECUs, should be simple enough to figure out what is not running.
  18. tbakowsky
    Sep 18, 2002
    20,038
    The Cold North
    Tom
    Wait..did I miss somthing? How is an F1 355 not a 5.2 car?
  19. yelcab
    Nov 29, 2001
    13,673
    San Carlos, CA
    Mitchell Le
    tbakowsky likes this.
