Buy
355, fiberous dust on cam belt
Discussion in 'Technical Q&A' started by ferrarioldman, Mar 18, 2004.
  1. ferrarioldman
    ferrarioldman Formula 3
    Jun 19, 2002
    1,027
    Summerfield, NC
    Tom Jones
    #1 ferrarioldman, Mar 18, 2004
    I thought that I had seen a thread on this subject awhile back but I can't seem to find anything in the archives. Upon performing a major service on a 355, I have found this brownish dust that has fibers in it in the cambelt area but can't find a source for it. This dust looks like it could be fiberglass or possibly even kevler. It has coated the cam belts and has built up inside the pulleys for the cams, in the tensioner brgs., and even inside the crank pulley. I have enclose a few pictures that I hope you can see what I am talking about. I have checked over everything in and around the front of the engine and cannot find and evidence of damage. The only possibilty I have found is that there is a cover under the F1 servo right behind the front of the motor that I believe it made from kevlar that was damaged and repaired with fiberglass at a previous time. Maybe when it was damaged some pieces were blown up into the cam belts and chewed up. I don't know. Anybody else seen this?
  3. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Blown header. Wrapped in glass cloth before the stainless cover goes on. Look closely at the heads and you should find heavier concentrations of it.
    Dave
  4. ferrarioldman
    Jun 19, 2002
    1,027
    Summerfield, NC
    Tom Jones
    Thanks Dave! You are probably right because I replaced an exhaust manifold about 6 months ago. I had forgotten about that.
