News
355 High idle and low oil pressure
Discussion in '348/355' started by tim355, Apr 22, 2009.
  1. tim355
    tim355 Karting
    Nov 7, 2003
    57
    I replaced the timing belts/tensioner bearings in my car and am very sure the timing is correct. Put everything back together and the car seems to run great except my problem is that the idle is very high, 2000 RPM and my oil pressure starts out at 70 PSI climbs to over 130 then drops to below 30 PSI, no lights. Now I know the high idle would indicate a vacuum leak but I have taken off both intake plenums twice and check everything I can think of but I still can't find the leak. now I'm wondering if there is some correlation between the high idle and low oil pressure. Any suggestions? Ideas? I hate to take it to the dealer if it's something simple.
  3. eyboro
    eyboro Formula Junior
    981
    Chicago
    Eitan
    If you just changed the oil on the car; synthetic oil id very thick and it takes a while for it to loosen up. You will see an increase in pressure after driving the car for 100 miles or so. I had the same problem after the 30k service.
  4. 355Aussie
    355Aussie Formula Junior
    634
    George
    It could be the idle regulator. If it is a 2.7 there are two at the end of the plenum covers so changing these from side to side may show you which one it is, Try looking at these.
  5. tim355
    tim355 Karting
    Nov 7, 2003
    57
    yes I have a 1995 (2.7 model) swapped the idle regulators without any change. the regulators seem to be working, (humming with the key turned on) I also tried disconnecting the regulators electrical connections and the idle is still high.
  6. notbostrom
    notbostrom Formula Junior
    May 8, 2006
    957
    Orlando, FL
    Ben
    this may sound silly but end play at the TB end of the throttle cable? have enough end play????
  8. tim355
    tim355 Karting
    Nov 7, 2003
    57
    nope, disconnected throttle cable. still idles high.
  9. notbostrom
    May 8, 2006
    957
    Orlando, FL
    Ben
    OK well easy enough to try.. I'd go back to the simple stuff first..
    not sure on 355 but is there a screw type adjustment for the TB closed position?. air has to be getting in for the idle to go up.. if not the TB itself air is getting in some place else.. just thinking out loud
  10. gidge348
    gidge348 Formula Junior
    Dec 12, 2008
    343
    Perth West Australia
    Ian Wood
    The oil guage stuff sounds like and loose connection or earth somewhere?
    I know you say that you have taken the plenums off and check but have you done the CRC test for vacuum leaks?
    Just get a can of CRC or any spray can with a hydrocarbon propellent (preferably not paint), start the engine and start spraying in all the hard to reach places around the plenum, hoses etc.
    If you have a leak you will hear the revs rise and get smoother when you spray the leak area.
  11. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    ....or temp senders and TPS's not getting the correct data to the ECU's.
    Connections at the rectangular plug behind the LR shock tower can muck up the pressure readings a bit as well.
  13. tim355
    tim355 Karting
    Nov 7, 2003
    57
    Well I finally took the car to Ferrari Of Seattle. They found the #6 throttle body was cracked around the circumference. It was impossible to see, until they began to tighten down the nuts that hold the throttle body down. I'm happy they found the problem!
  14. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,760
    Hamilton, NewZealand
    James
    WOW!!! That seems a strange problem. Are they going to weld it up or replace it?
  15. PAP 348
    PAP 348 Moderator
    Moderator Owner
    Dec 10, 2005
    86,840
    Mount Isa, Australia
    Pap
    Interesting, never heard of that one before. :D:D
    Have you or they got any pics mate?? Would love to see it. :):)
  16. tim355
    tim355 Karting
    Nov 7, 2003
    57
    They are going to try and weld it. New ones cost $1800. I don't have any pics to post, sorry.
  17. PAP 348
    PAP 348 Moderator
    Moderator Owner
    Dec 10, 2005
    86,840
    Pap
    Cool, hopefully they have a win welding it up. :):)
