355 hydraulic tightener replacement? | Page 2 | FerrariChat
Discussion in '348/355' started by TrojanFan, Jan 21, 2025.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,682
    San Carlos, CA
    Mitchell Le
    I don't think Pete is planning on changing the oil pump drive chain tensioner. Although, if he wanted to do that, now would be the time.
  2. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,191
    So. CA & NV
    Peter
    I'm trying to avoid too much of the "while I am in there" syndrome.
    I have a new water pump so going to replace that. May do all the hoses too since the engine is out.
  3. yelcab
    Nov 29, 2001
    13,682
    San Carlos, CA
    Mitchell Le
    Replace the four hoses at the radiators. It's easy now.
  4. Rifledriver
    37,288
    Drive bearing is rare. I typically only change tensioners when there is a history of rattle at startup. Thats far less rare. The good news is if they do totally fail it just rattles and tells you to replace it.
    As far as using its collapsed position as an indicator they do that quite commonly when the motor kicks back when shut down. Its like a hydraulic lifter and left an hour or so with extra tension on that side of the belt from the motor turning back at shut down they'll all do that.
    GatedF355GTB likes this.
