355 lites dim when I put on the brakes | FerrariChat
Discussion in 'Technical Q&A' started by mondial86, Dec 13, 2003.
  1. mondial86
    mondial86 Formula Junior
    Nov 1, 2003
    298
    MA
    David Holmes
    Last nite I as I was driving home in the 355 every time I put on the brakes the lites would dim ,at one point it caused the stero to cut out and then came right back on .The lites also dimed when I would use the blinkers.,also the raido works great untill you run the car then shut it off come back start it up then there is a verr high pitch wine it ,the wine goes up and down in freequeancy as with motor rpm's.I am not sure but I think the light problems only hapen when the radio is doing it's wine thing. any ideas it is a bit wierd
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,252
    A) Alternator
    B) Battery
    C) Ground
  3. BigHead
    BigHead Formula Junior
    Oct 31, 2003
    995
    Outside of Boston
    Dennis
    The 355, especially early ones, have a ground problem with the alternator. To resolve this, on later cars a BIG ground strap was added.
    I had the same problem, only worse. After installing the ground strap, when we tested the ground with the engine running, the voltage jumped from ~11v to 13.7v. We installed the revised ground strap from Ferrari ($20! For a wire!), but one suppose you can just wire up a groundstrap yourself. Part # 180904.
    For other 355 owners out there, my understanding is that this ground strap is yet another friggin' legendary silent retrofit part from Ferrari, not unlike the sticky throttle cam replacement part. Urgh... Only weeks of frustration. Oh well.
    Let us know if this solves the problem.
    vty,
    --Dennis
  4. tonyc
    tonyc Formula 3
    Oct 19, 2003
    1,639
    Monterey, CA
    Tony C
    I noticed a similar problem on a 99 355. Next time I have the car on a lift I will replace this also. Oh the joys of Ferrari ownership :)
    --tony
