355 loss of power and slow down light | FerrariChat
Discussion in '348/355' started by u2fast, Jun 6, 2025.
  1. u2fast
    u2fast Formula Junior
    Mar 22, 2009
    256
    bellaire
    barry r
    Advice needed. I have owned my 355 spider since 09. Lately and occasionally when I hit a small bump my slow down light comes on and I’m losing power to one side. Is there something that is a common problem? Loose connection etc? Having my major later this year but I prefer to address this now on my own if possible. Many thx for the update king info. Barry
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,683
    Sounds electrical.
    Qavion likes this.
  3. Qavion
    Qavion F1 World Champ
    14,100
    Ian Riddell
    Do you have a 2.7 or 5.2 (i.e. two Slow Down lights or one)
  4. u2fast
    Mar 22, 2009
    256
    bellaire
    barry r
    5.2. One slow down light
    I think it’s electrical too. Just not up to speed on what connections I need to look at
  5. Qavion
    14,100
    Ian Riddell
    I'm assuming the light is coming on because of a false overtemperature signal being sent to your ECU. I don't know if a bad connection triggered by vibration can cause the thermocouple or Thermocouple ECU to generate a light, but the internal electronics have been known to break down in the Thermocouple ECUs.
    What colour is the potting compound on your Thermocouple ECUs? Green or black. Your car should have 3 TCUs. Two on the right and one on the left.
    Left TCU with green potting compound.
    You may have to invest in a cheap OBD scanner to tell you which one is faulty. Otherwise, you'd have to either buy a new one and swap it out with the old ones (one by one) or fabricate a dummy TCU from a resistor and zener diode. The dummy ECU bypasses both the thermocouple and Thermocouple ECU.
    Note.... Aftermarket, cheaper than OEM TCUs are available from Technistrada (New Zealand)
    Of course, I'm assuming your cats are in good condition. Broken bits of catalyst may be rattling around, periodically causing real overtemperature.
    By the way, is your Check Engine Light working? Does it come on at engine start?
  6. Qavion
    14,100
    Ian Riddell
  7. m.stojanovic
    m.stojanovic F1 Rookie
    3,191
    Serbia - Niš
    Miroljub Stojanovic
    Bad (loss of) connection of a Thermocouple to the TCU is interpreted as if the EGT is too high and will cause SDL and bank shut-down.
    Qavion likes this.
  8. JoeCab
    JoeCab Formula Junior
    396
    Colorado
    Joe C
    I had a similar problem earlier this year. I would get a momentary flicker of both the SDL and CEL accompanied by a violent, but momentary, loss of power. It happened so briefly that it didn't set the CEL.
    It was a cracked connector to the crank sensor. Vibration at various RPM or bumps would cause a loss of signal. "Pending" P0336 trouble code gave it away immediately. Replaced sensor and no further problems.
    Qavion likes this.
  9. u2fast
    Mar 22, 2009
    256
    bellaire
    barry r
    Here is a pic of the left side. I found one of the two on the right. It matches the left side. Where is the third.
    my cats are fairly new and so are my headers. Running capristo 3 exhaust.
    I good bump in the road was causing the slow down light and loss of a bank. Has not caused the CEL to come on though. The last two slow down lights this week were not caused by a bump in the road.
  10. Qavion
    14,100
    Ian Riddell
    It should be in the same general area under the secondary air pump. See the graphic I posted earlier (item G is shown twice). I don't know if your Capristo installation deletes the exhaust bypass valve Thermocouple ECU. I think you would need some kind of Motronic ECU software update to do that, though. A few folks have tried to put a dummy TCU in that position, but still get warning lights. The logic in the Motronic ECU processes the signals from exhaust bypass Thermocouple ECU differently from the CAT Thermocouple ECU signals.
    Or did this warning light only appear after the installation of the Capristo?
    It looks like your car has been driven in the rain.... and I don't like the way the potting compound is pulling away from the case.
    Your potting compound seems to be the better green colour, but these green ones still do fail. Anyway, clean the pins on the plugs with non-residue electrical spray (not WD40). Let dry and reinstall the plugs.
    If you can't find that 3rd Thermocouple ECU, see what the single ECU is attached to... The exhaust bypass or the RH Cat.
    I have seen a workshop manual graphic showing the bypass valve thermocouple wired directly to the Motronic ECU, but no one seems to have that configuration.
  11. Qavion
    14,100
    Ian Riddell
    If you do find the 3rd Thermocouple ECU... and the wiring harnesses are long enough on the RH side, try swapping over both plugs on those RH ECUs (it may be slightly easier than swapping over the TCUs). If the RH Cat Thermocouple ECU is causing the issue, you may solve the bank shutdown issue, but still get warning light/s during a drive.
    How easy is the problem to reproduce during a bumpy drive?
  12. u2fast
    Mar 22, 2009
    256
    bellaire
    barry r
    Very good advice. Very rarely seen rain. But have been caught in it a time or two over the years. When I have a loss of power and the slow down light comes on, I still do not get a check engine light. Most of the time this event occurs right when I hit a bump with the exception being the last two times last Friday. The capristo has been on the car for 10 years along with the cats. The tubi headers are less then a year old. I don't think any of the exhaust components are related to the issue. thx for your thoughts. Barry
    Qavion likes this.
  13. Qavion
    14,100
    Ian Riddell
    If the plug cleaning doesn't work, for faultfinding, unless you haven't got a soldering iron to string a diode and resistor together, I would be buying a dummy TCU from Technistrada or even one of their Thermocouple ECUs.
    https://technistrada.com/
    They are a different size to the OEM ECUs, and lighter, but unless you are stickler for originality, it won't make a difference.
  14. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,467
    San Carlos, CA
    Mitchell Le
    Replace that TCU with the lifting epoxy.
  15. Qavion
    14,100
    Ian Riddell
    Just tested this on my own car ('98 5.2). I pulled the two pin plug on the left TC ECU and started the engine. After about 5 seconds the engine tone changed (although I was surprised at how relatively smoothly the engine ran... just a little imbalance at idle). I turned it off a few seconds later in case I broke something. I forgot to check which lights were on. I reset the plug and all was ok.
    EDIT: Unfortunately, I can't see how this can be used as a faultfinding tool where the car is only fitted with one SD light on the dash. I repeated the exercise with both sides pulled, but the engine still ran on one bank. I turned off the engine, reset the plugs and restarted the car, but the SD light was now flashing. I pulled and reset the plugs again but still no joy. I don't know if this was a glitch, but I used my scanner to clear it and the light disappeared. My previous single plug test didn't generate an SD light after reconnecting the plug and restarting the car. Maybe it was a case of two strikes and you get a permanent flashing light, even if you put everything back to normal?
