News
355 power loss
Discussion in 'Technical Q&A' started by tim355, Aug 20, 2004.
  1. tim355
    tim355 Karting
    Nov 7, 2003
    57
    I own a 1995 355 Spider. I was driving home from Seattle last night and when I went around a corner the engine suddenly lost power. After turning the car off and on a few times (still no help) I limped the car home 20 miles or so but struggled at every hill and stop sign. This morning I drove the car to town ( no issues) but in town when I started it up again I had the same problem. It's like I've lost all power on 1 bank. I have not had a "slow down" or "check engine" light come on. Any ideas what I should check for?
  3. BigHead
    BigHead Formula Junior
    Oct 31, 2003
    992
    Outside of Boston
    Dennis
    Bad ECU, very common. Try swapping from side to side, see if the other side is afflicted. But it should light up your "Slow down" light. Hmmm....
    vty,
    --Dennis
  4. Rjones355
    Rjones355 Karting
    Jul 6, 2004
    62
    Rancho Murieta, CA
    Ryan Jones
    I had a similar problem, I unpluged the fuel pump fuses and the air flow meters, and the problem went away. It has not came back as of yet, I am also confused because like you no lights came on. If you figure it out let me know.
    Ryan
  5. f355spider
    f355spider F1 World Champ
    Rossa Subscribed Owner
    May 29, 2001
    17,061
    Hugh G. Rection
    Interesting that it is "intermittent", is it possible that the connectors to the ECU's need a thorough cleaning...and possibly treated with some contact enhancer like Stabilant 22? Or is intermittent operation, just the sign of a failing one?
  6. tim355
    tim355 Karting
    Nov 7, 2003
    57
    thanks guys, I'll follow your suggestions, hope it's not an ECU. Anyone Know what they cost?
  8. tim355
    tim355 Karting
    Nov 7, 2003
    57
    Well after a lot of work I finally traced the problem down to a broken connector in the fuse box under the passengers foot rest. (relay female pin for 1-4 injectors) This seems really wierd. Car only has 26K miles on it. Has anyone else needed to replace the fuse box? Anyone out there have a part-out 1995 355 with a fuse box I can buy?? I'm sure a new one from Ferrari is very expensive.
  9. jeffdavison
    jeffdavison F1 Rookie
    2,500
    Suwanee Georgia
    Jeffrey Davison
    I had a power loss from a couple of fouled spark plugs. Put a new set in and vviola! vroom vroom. About a $50 buck fix.
    JD
  10. FL 355
    FL 355 Formula 3
    Nov 3, 2002
    1,665
    Ft Laud
    Frank Lipinski
    Tim
    FerrariAds.com on this site. Add 2239
  11. fatbillybob
    fatbillybob F1 World Champ
    Aug 10, 2002
    19,023
    socal
    Geez Tim,
    I hate electronics. Can you explain to me the process you use to trace down such a problem and what are you using to do it. I need some lessons from a wizard with a VOM!
