355 range w/o alternator | Page 2 | FerrariChat
Discussion in '348/355' started by F129b, Dec 27, 2015.
  1. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    18,031
    wisconsin/chicago
    bo
    My alternator squeals when it first turns over... So I know when it kicks in...
    I can drive my testarossa about 30-40 minutes before it kicks in. That's on a 2 year old battery that lives on a trickle charger... No radio or airconditioner, low revs...
    The battery in a testarossa is pretty big...
  2. bpu699
    Dec 9, 2003
    18,031
    wisconsin/chicago
    bo
    Just go buy another car battery for $100 and keep it in your trunk. Change it out if the original one runs low...
  3. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    #28 Meister, Dec 28, 2015
    They can grab onto the lower frame/front a arms. Just be aware/careful when they tighten the cable that it doesn't rise too much and damage the front chin spoiler. I've had my 348 winched onto a flatbed and if they can get that on, they can get a 355. It just takes time and care. Don't just assume every truck driver isnt going to care. Get in touch with some of the local specialty/hot rod/car shops/dealers. Those guys often use flatbeds and will have trusted guys/truckers who know how to move nice cars.
  4. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    Please don't take offense, but the risk vs reward ratio is simply not there. Flatbed is the right answer... if the injectors start tailing off you risk running lean, if the ignition doesn't reliably fire the plugs you'll be dumping fuel on the cats, and if nothing goes bad you will have saved a few dollars.
    If you are set on doing this, make sure that you have a fully charged battery, start it with a booster battery, and have a back-up plan. Don't run any electrical stuff and don't run any accessories that you don't need (to include AC, blower fans, stereo, lights, etc).
    Now, if it were me, I would just remove the alternator and drive it over to where you need it repaired/replaced, drive home, and install it. I mean if you are seriously trying to save some money, do the job yourself. The towing bill can't be that much.
  5. Markphd
    Mar 10, 2012
    713
    I am in San Clemente if that helps... I would let you charge up here. As far as the flat bed goes, with care the car can be winched on without damage. BTW, there is more clearance if you pull the car on backwards, but that means being careful as the nose rotates towards the ground.
  6. F129b
    F129b Formula Junior
    Feb 6, 2004
    523
    oc, calif.
    Robert
    Appreciate that mark, but I'm already north of you-Bear Brand Lag Niguel. Not about saving $$
  7. F129b
    Feb 6, 2004
    523
    oc, calif.
    Robert
    The latest plan-guaranteed success according to my Wrench: top off battery w trickle charge tonight. Connect Jump Pack/antigravity battery pack to engine bay posts. Zip tie it in place. Larry says no question I will make it 25-30mi to Orange/his shop in this config.
    What I do now know is that I can start the car and drive for 10-12 mins to a destination and connect trickle charger for 1-2 hrs in between jaunts. Did 3 of these today, no prob. Battery is a die hard 34R
  8. plugzit
    plugzit F1 Veteran
    7,816
    Redondo Beach, CA
    Bruce Bogart
    Don't leave antigravity battery connected. !!!!!! Ask me how I know.
  9. F129b
    Feb 6, 2004
    523
    oc, calif.
    Robert
    Tell me Bruce. This was larrys idea. He said he ran F50 this way under similar circumstances.
  10. plugzit
    plugzit F1 Veteran
    7,816
    Redondo Beach, CA
    Bruce Bogart
    I'm wrong in your case. No alternator, no problem. OOPS
  11. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    You did 3 "jaunts" of 10-12 minute drives followed by 1-2 hrs of trickle charging in between each drive today and you don't have "time to sit around" for a tow truck to show up? At this point just drive the thing and let us know how it goes.
  12. F129b
    Feb 6, 2004
    523
    oc, calif.
    Robert
    Made it w/o issue. The answer in my case is 29.7 miles in 37 minutes.
    My contribution for data collection in '15.
  13. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    Awesome, I knew you'd make it.
  14. 05011994
    05011994 Formula 3
    May 1, 2004
    1,865
    Golden, Colorado
    Back in 2012 I drove from Sante Fe New Mexico to Denver with no alternator, fresh battery with a 2 hour lunch break in Raton to recharge and another hour in Colorado Springs to recharge. Would not want to do it again, but with a fresh battery and charger it can be done.
  15. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    sweet! Remember exotics are like dogs, they can smell fear :) Don't let your guard down
  16. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    glad to hear you made it . :)
