Buy
355 rear challenge grill install
Discussion in 'Technical Q&A' started by frisbee54, Apr 10, 2004.
  1. frisbee54
    frisbee54 Rookie
    Apr 1, 2004
    29
    Napa CA
    Douglas Morgan
    Hi is it fairly easy to install the rear challenge grill on a 355? and do you use the horse off of your own cars rear on the challenge grill? Thank You Doug
  3. Capt
    Capt Karting
    Nov 9, 2003
    222
    North of Boston
    Michael
    Yes and Yes.
    Took me like an hr to take mine off and put the new one on. I would recommend running the nuts down all the studs *before* mounting it on the car. I got it on, only to have to take it off becuase the studs in the lower corners (on the outside edge of the tail lights) wouldn't let the nuts thread on.
    -Michael
  4. frisbee54
    frisbee54 Rookie
    Apr 1, 2004
    29
    Napa CA
    Douglas Morgan
    Thank You
    Doug
  5. Capt
    Capt Karting
    Nov 9, 2003
    222
    North of Boston
    Michael
    Doug,
    Have you tackled this yet?
    -Michael
  6. JDSF355GTS
    JDSF355GTS Rookie
    Jan 29, 2004
    36
    Hey guys, I noticed your thread and have tried the install myself. I got to the last 2 nuts, one on each side of the middle brake light and stopped. There seems to be a piece of aluminum on the outside rear of the car above the brake light that is secured by a rivot on each side that prevents me from getting to those. I was afraid to drill the rivots out. Did you do that or come up with a better solution? Thanks! J
  8. frisbee54
    frisbee54 Rookie
    Apr 1, 2004
    29
    Napa CA
    Douglas Morgan
    Ihaven't done the swap yet
    Doug
  9. felix66
    felix66 Karting
    Feb 21, 2004
    175
    London
    I'm having a go at this at the moment but there is a trim strip that appears to be riveted at either end which holds the stip of perforated metal in place wiht the f355 badge on it. Does anyone know how to remove this?
    I can't get to the two top mounts of the grill with this in place.
  10. felix66
    felix66 Karting
    Feb 21, 2004
    175
    London
    Ok - sorted it - drilled out the rivets and used two anodised black 3.2 m rivets and rivet gun to replace it afterwards
  11. Mickey
    Mickey Formula Junior
    Jan 20, 2004
    409
    Linnet Drive
    Felix,
    it would be real help if you could take us through it with pics ?
  13. felix66
    felix66 Karting
    Feb 21, 2004
    175
    London
    sorry mickey I have already done it now.
    You need a staedy hand and to a small drill bit to remove the outside edge of the two current rivets. then once they are gone - reach inside the back of the wing and remove the debris.
    The strip of thin metal holding the pre-exisitng perforated piece of trim (with the 355 badge on it) will then pull away and allow the 355 bage panel to be removed. You can now get to the last two remaining nuts holding the existing prancing horse panel to be removed. - It took me an hour or so to remove everything and around twenty mins to put it all back together again - note - you need a small pop rivet gun and some 3.2mm rivets to re-attach the metal strip.
  14. Skipper
    Skipper Formula Junior
    Sep 24, 2006
    445
    Frank Drebin
    so no way around drilln and reriviting
  15. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    11,608
    South East
    Jimmie
  16. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Unfortunately.......... no .... :(
