News
355 Spider seat/top switch console bezel
Discussion in '348/355' started by Carmellini, Dec 10, 2020.
  1. Carmellini
    Carmellini Formula Junior
    Jul 16, 2019
    434
    My power seat/top switch bezel is missing both the rear tabs and is not locked into position. Anyone have a reasonable one with 4 solid tabs? ...Or.....
    does anyone have a good solution to keep it fixed in place. it stays in place fairly well, but if there is some trick to make it better,........??????
  3. Challenge
    Challenge Formula 3
    Sep 27, 2002
    1,533
    PA
    Kevin
    The 2 tabs closest to the back of the car were half broken when I removed this bezel. I used to hate how it would shift around. I ended up plastic welding the tabs successfully.
    One tip on installation: do not simply jam the bezel back in its spot, thinking the tabs can handle the force. Use one hand to reach through the switch openings and push the leather rearward while VERY gently popping the bezel in place. This will give you the extra clearance you need. Then pop your 3 switches in. Mine is rock solid now.
