News
355 sticky goo removal
Discussion in '348/355' started by f355 Nashville, Sep 19, 2004.
  1. f355 Nashville
    f355 Nashville Karting
    Feb 5, 2004
    154
    Nashville, Tn.
    Ting
    i found a spray that will take the sticky goo right off the 355 surfaces. it doesnt damage the plastic under the sticky paint like turpantine and it works 10x better than goo gone. on one website its called "tri-clean"
    heres a link
    http://www.worlduph.com/semdye.htm
  3. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,792
    Jupiter, FL
    Paul Bianco
    what sticky stuff was on the 355?
  4. FL 355
    FL 355 Formula 3
    Nov 3, 2002
    1,665
    Ft Laud
    Frank Lipinski
    Thanks for the info....just ordered a can.
    I'm going to re-do my entire car...see thread in tech under "355 bubbling center consol" by Pete Delany.
    Any useful tips regarding application? After spraying what did you use? Scraper blade or teflon pad or what?
    Frank
  5. richard_wallace
    richard_wallace Formula 3
    1,950
    Cincinnati, Ohio
    Richard Wallace
    Frank,
    I believe that you must drink a minimum of 3 beers before applying ;)
    Take pic's - even though I ordered the part from Pete - mine has yet to bubble or start to get sticky yet - I am just preparing for my day - cause I know it will come.
    Hope all is well,
    Rich
  6. f355 Nashville
    Feb 5, 2004
    154
    Nashville, Tn.
    Ting
    i accidently discovered this stuff. i bought some leather dye, for my mercedes steering wheel... they suggested that i use this tri-clean stuff to clean the leather surface before i spray the dye on. i saw some paint on the vin number plate on the top of the steering column.. so i tried to get it off with the tri clean.. i didnt expect the stuff to melt the sticky goo like it did. so i started with cleaning off the vin number plate to taking off the sticky steering column cover (which i had given up on) and cleaning it off completely.
    all i did was spray the tri-clean on the surfaces. then scraped with a credit card, and finished off with a clean towel. i did the steering column this way. a few months ago i did the ac control, shifter surround and ash tray cover with goo gone and turpintine, what took me 6 hours to do would only take 30 minutes if i had the tri-clean spray. i am swearing by this stuff. let me know how it works for you.
  8. FL 355
    FL 355 Formula 3
    Nov 3, 2002
    1,665
    Ft Laud
    Frank Lipinski
    OK - I'll post comments when done. I know it's a slow and messy project.
    Richard - Of course I'll take pix step by step and post..I think there's about 15 of us.
    Pete's last post said the cover should be ready today (21st) so I expect to begin next week...the same time Tri-Clean arrives. They are in CA and can only ship via ground. I'm guessing 3-4 days for the entire project.
