355 "STOP" button LED replacement | FerrariChat
Discussion in '348/355' started by Carmellini, Jan 6, 2021.
  1. Carmellini
    Carmellini Formula Junior
    Jul 16, 2019
    814
    My STOP button LED needs replacement; What is the bulb spec? Does the button cover pop off to expose the bulb? Or do I have to disassemble the AC panel?
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,667
    CT
    John Kreskovsky
    It's not an LED.
    You will need a 7219 bulb but best to replace both the STOP and RECIR bulbs so they are the same brightness.
    https://www.jacksonelectricsupply.com/7219-Miniature-Bulb-Wire-Terminal-Base-p/7219.htm?gclid=Cj0KCQiA3NX_BRDQARIsALA3fIKf4eVdPFKbQbg-53WD-fL25TzoRNfjaQ8bPLPiEqZMfFQDPeKPtEgaApamEALw_wcB
    And you may need a couple of green "socks".
    https://www.ebay.com/itm/XPT01G-100pcs-GREEN-Caps-Covers-for-3mm-Grain-of-Wheat-Bulbs-LEDs-NEW/221101885073?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20160908105057&meid=bfcd97b7db6c43d7b9106d986461616d&pid=100675&rk=2&rkt=15&mehot=ag&sd=152148738326&itm=221101885073&pmt=1&noa=1&pg=2380057&brand=Unbranded&_trksid=p2380057.c100675.m4236&_trkparms=pageci:bfd69ba5-503a-11eb-aee6-3ed869ded0fb|parentrq:d87da70f1760ad4a4ceda718ffd8a56e|iid:1
    To replace the bulbs you have to remove the HVAC panel. Then remove the PCB from the housing and unsolder to old bulbs and solder in the new one in. If you can't removed the original green socks from the old bulbs and need to use new one you have to carefully cut off the ridge at the bottom of the new sock if they have ridges.
    Mike Morrissey, Qavion and 308 GTB like this.
  3. Carmellini
    Jul 16, 2019
    814
    ^^^^ Exactly what I was looking for....Thank you very much.
  4. Carmellini
    Jul 16, 2019
    814
    seems relatively simple, but before I dive in, are there any tips/tricks separating the unit? Do the knobs come off separately or are they part of the upper part of the housing?
  5. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,847
    Southern Md
    Robbie
    We have done about 50 of them if you need someone to take care of it. Disassemble the panel and replace both bulbs. The bulbs must be soldered on.
  6. johnk...
    Jun 11, 2004
    10,667
    CT
    John Kreskovsky
    Once you take the PCB out of the housing the rest is obvious. But it's best to use some desoldering braid to remove the solder from the old bulbs joints so the PCB hole are clear.The bulb is mounted on little standoffs.
    Image Unavailable, Please Login Google No-clean wick.
    If you like, send it to me. I'm in CT. I'll fix it for free just pay return shipping. I've done a bunch.
    308 GTB and Qavion like this.
  7. Carmellini
    Jul 16, 2019
    814
    WOW....What an incredible offer.....will give it a try, but if I get in a jam, I will get in touch. Thank you again.
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    Hi John
    Could I send you my motor?
    Mike Morrissey likes this.
  9. johnk...
    Jun 11, 2004
    10,667
    CT
    John Kreskovsky
    Only if you don't want it back.
