355 Subframe : Upper Wishbone Brackets | FerrariChat
Discussion in '348/355' started by FourthAlfa, Mar 24, 2019.
  1. FourthAlfa
    FourthAlfa Karting
    182
    Paris, France
    Andrew Love
    Hi Folks,
    If I understand well, the design of the upper wishbone brackets (on the rear subframe) evolved due to weakness where they are welded to the subframe. It seems that it is not uncommon for subframe to crack in this area. I have an early M2.7, with the start of crack so will reinforce this while the engine is out. Would someone with a later car mind posting a picture of the upper wishbone brackets (front and rear) of a later car to see what design upgrade was implemented? (I believe it was just a larger fillet radius). Below are the brackets that I am speaking of.
    Thanks! Image Unavailable, Please Login Image Unavailable, Please Login
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,942
    Indio Ca/ Alberta
    Grant
    Someone posted this before because i thought the challenge cars were all done before the raced or shortly after.
    Theywere gusseted fro what i remember.
    Maybe Tim or Fbb have that info
  3. krazykarguy
    krazykarguy Formula Junior
    Apr 17, 2014
    716
    Fort Mill, SC
    Matt
    I checked a couple of pics from our recent engine out, and ours is a '97. The two pics below are the best images I could find of the area you're looking for.
    It looks like the mounting bracket extends quite a bit lower down the subframe tube than the early cars.
    FourthAlfa likes this.
  4. FourthAlfa
    FourthAlfa Karting
    182
    Paris, France
    Andrew Love
    Thanks Matt and Tim!
    That is perfect.
    Looks like it is just the front one that got the bigger fillet
    SoCal1 likes this.
  5. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
  6. 308 GTB
    308 GTB F1 World Champ
    11,166
    New Jersey
    Barry Wolinsky
  7. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,487
    Lake Villa IL
    Tim, if you get a chance sometime I’m interested in the weight of that subframe :)
    SoCal1 and Dave rocks like this.
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,942
    Indio Ca/ Alberta
    Grant
    What the hell are we looking at.
    Cause i cant see it.
    Is this like a Wheres Waldo game??
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,942
    Indio Ca/ Alberta
    Grant
    Before Tim posts lets get some guesses
    Mine is 64 lbs
  10. krazykarguy
    Apr 17, 2014
    716
    Fort Mill, SC
    Matt
    If we're playing by Price is Right rules, my guess is 65 lbs. :p
    taz355 likes this.
  11. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,562
    SoCal LA/OC/New Mexico
    Tim Dee
    Just weighed it
    With crossmembers and the motor mount bushings way more then I thought, 100.8 pounds
    I got to stop messing with big girls when 100 pounds feels like 45 LOL
    INTMD8 and MAD828 like this.
  12. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,942
    Indio Ca/ Alberta
    Grant
    Thanks Tim
    James can now lower his car 50 pounds more with chromoly tubes
    SoCal1, Dave rocks and INTMD8 like this.
  13. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,487
    Lake Villa IL
    Thanks for weighing it Tim!
    Grant, you read my mind :D Probably not 50lbs but definitely some room for improvement.
  14. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,562
    Tim Dee
    ItsI a really clunky old design that's very weak
    Aluminum, chromoly even a hybrid with different geometry would be fun to try
  15. FourthAlfa
    FourthAlfa Karting
    182
    Paris, France
    Andrew Love
    Thanks Barry for the confirmation of what the challenge cars have as well. Nice to know it is the same solution!
  16. 308 GTB
    11,166
    New Jersey
    Barry Wolinsky
    You're welcome, Andrew. Another weak point on the 1995 cars are the front shock mounts. The metal is very thin there and prone to cracking with the 2200 lb/in front Challenge springs. The 1996 cars have bolstered mounts and the Challenge Manual for that showed parts for strengthening the area. My car never had the modification when it raced. I had it done a few years ago...
  17. GTUnit
    GTUnit Karting
    May 25, 2014
    143
    Socal
    Jack
    Does anyone have any instructions on the recommended reinforcement?
  18. FourthAlfa
    FourthAlfa Karting
    182
    Paris, France
    Andrew Love
    Barry, thanks again for he heads up on weak point in the front! Will check it out.
    As far as reccomendeded reinforcement, I think doing just as Ferrari did on the later subframes would be the reccomendation (but maybe there was a technical bulletin?) It is not really a difficult problem to solve, I am sure any type of gusset/fillet would basically work. I will reinforce mine just as the later cars have it, with the big fillet.
  19. PaulK
    PaulK F1 Rookie
    4,603
    Michigan
    Paul
    I will have to check these mounts out. I have a '95.
