355 Teves ABS help | Page 2 | FerrariChat
355 Teves ABS help
Discussion in '348/355' started by Jpwulf, Jul 12, 2024.
  1. m.stojanovic
    m.stojanovic F1 Rookie
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    I see some strange statements on the second page about the Main Relay (should be green colour). Assuming that the 355 Teves ABS Main Relay is the same as that in the 348:
    1. It is not clear what they mean by "main relay internal resistance". If it is between the contact points for pins 30 and 87a (normally closed points), the resistance cannot be so much unless the contacts are burned but they carry only a small current which is for the small bulb in the abs warning light and perhaps a little more for grounding two of the ABS ECU pins. If the resistance between 30 and 87a was ~100 Ohm, then the ABS warning light would not be "on" or would light rather dim. If the mentioned 100 Ohm is of the relay coil, this is the normal resistance of it and it may go up by one or two ohm with temperature.
    2. "Unable to find a replacement" - this is a very standard automotive 5-pin cube relay with pins 85, 86, 30, 87 and 87a. This relay is also called "change over relay" since 30 to 87a is normally closed and 30 to 87 is normally open (and they switch their states when the relay is energised). You can get this relay at almost any car parts shop.
    3. "Attempted to swap pins..." - this makes no sense; what "compatible" relay they attempted to use? A standard 5-pin relay, as described above, just plugs in.
    It is possible that your Main Relay is faulty and does not engage (or possibly somebody put a wrong relay there ?). As I mentioned in post #10, if this relay does not engage, the ABS light will stay "on" and you will not have ABS function when breaking.
    I suggest you get a new relay and give it a try. It should have a diagram on it and pins like on this picture:
    Buckets and Qavion like this.
  2. Jpwulf
    Jpwulf Karting
    Sep 26, 2022
    81
    Oregon
    John Wulf
    Thank you!!! I'll give some searching around town locally to see if I can find this 5-pin relay! Man, I sure hope it's this simple...
  3. m.stojanovic
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    Have look at the diagram on the existing relay in your car and the markings at its pins, just to be sure the new relay has the same markings. You should bring the original relay with you when looking for a new one.
  4. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,930
    Richmond
    Pete
    Check the ABS computer ground for continuity in the harness. I had an issue with a burned ground in the ABS computer on mine, I resoldered and it worked fine, but as the dealer swapped ecu's and it still did it, ground is an easy check.
    Jpwulf and Qavion like this.
  5. Jpwulf
    Jpwulf Karting
    Sep 26, 2022
    81
    Oregon
    John Wulf
    so none of the relays match what you posted… BUT, I found a relay at my local store that matches what you posted above. Is a wrong relay in my car? I have the black relay with the white dot, an orange relay, a green relay, and a 4 pin black relay.
  6. Jpwulf
    Jpwulf Karting
    Sep 26, 2022
    81
    Oregon
    John Wulf
  7. Qavion
    Qavion F1 World Champ
    14,601
    Ian Riddell
    Definitely not. The "relay with the white dot" is not a relay. It's a module with only two diodes in it.
    The main relay is the green relay
    There should be a large PINK wire coming from the 30 amp fuse to pin 87 of the relay socket.
  8. Jpwulf
    Jpwulf Karting
    Sep 26, 2022
    81
    Oregon
    John Wulf
    Got it! The green relay I removed doesn’t match the pins shown on what was posted above and the relay I purchased…? Just want to be sure I’m not plugging in something I shouldn’t be!
  9. Qavion
    14,601
    Ian Riddell
    Interesting. If that green relay is the correct type, it doesn't look like a standard changeover relay. Actually, looking at the pin configuration, it doesn't look like any of those relays are standard.
  10. Qavion
    14,601
    Ian Riddell
  11. Qavion
    14,601
    Ian Riddell
    You can double check your tech's relay test.
    With no power applied to the relay, you should have zero ohms between pin 87a and 30. With the coil energised (with a small battery across pins 85 and 86), you should have continuity between 87 and 30. Also make sure you have power at the relay socket (pin 30) and, as suggested by Pete @bobzdar make sure you have a good ground on relay socket (pin 87a).
    Check the resistance of the relay coil across relay pins 85 and 86
  12. Qavion
    14,601
    Ian Riddell
    Green relay energised test:
    With the other relays, they have diodes across the coils, so you have to get the battery polarity correct. Further instructions will be required.
    Maybe a small 9 volt battery would be better for the test than a 1.5v.
  13. Qavion
    14,601
    Ian Riddell
    That photo of your black (pump) relay doesn't seem to match the wiring diagrams (I'm assuming it's not the one with the white dot on it). The pin numbers are 87a, 87b, 87c, 30 and 87d. The wiring diagrams show a 4 pin relay with 87, 85, 86 and 30. I'm not sure how I would go about checking that other than trying to use pin 30 as a reference (assuming it is power with a big red wire going to it).
  14. Qavion
    14,601
    Ian Riddell
    I'm starting to wonder how the relays are configured internally. Have Teves rewired the internals of the relays or just put different numbering on the base of a standard Bosch relay to confuse everyone. If you can match specific relay base pins to vehicle wire colours, perhaps that would be the better way to go. At least we know what the wires are attached to.
  15. Qavion
    14,601
    Ian Riddell
  16. Jpwulf
    Jpwulf Karting
    Sep 26, 2022
    81
    Oregon
    John Wulf
    Qavion likes this.
  17. Qavion
    14,601
    Ian Riddell
    Does the green relay have a schematic on the side?
    Does it correspond to this diagram?
    e.g. Are pins 85 and 86 the coil or something else
  18. Jpwulf
    Jpwulf Karting
    Sep 26, 2022
    81
    Oregon
    John Wulf
    I just verified the numbers on the relay match where the diagram is showing for the wires. So it seems to be correct, even though the relay itself looks different.
    Qavion likes this.
  19. Qavion
    14,601
    Ian Riddell
    If this relay nil stock situation gets worse, I can see that 348 owners are going to have to modify their relay sockets to allow standard relays to be fitted.
    Did you find a 9 volt battery? You could probably put the battery terminals directly across the green relay coil pins to activate the coil (without using test leads) and put your multimeter probes on 30 and 87.
  20. m.stojanovic
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    There are two pin configurations for change-over (and other) cube relays:
    Note the swap of the pins 30 and 86 on the right relay. The two types are internally same except for the different pin arrangement. The type at the right is rarely used (BMWs of the 80s had them, Hella) but it is still available. The standard type (left) can be used in place of the "special" (right) relay if the sockets 30 and 86 in the relay connector are swapped.
    After looking at some pictures of the Ferrari 348 ABS "green" relay, it appears that its pin configuration is like on the pinout shown on the right pic above, i.e. "special". It also appears to be Siemens V23134-E52-X84. I see one on Ebay: GENUINE FERRARI 208 308 348 SIEMENS Brake System Electronic Unit Relay 131938 | eBay. The question is: is the 355 ABS green relay same as the 348 green relay?
    If the 355 green relay is same as the one on the 348, then its pinout should be like the pinout on the right picture. In this case, you can either buy a change-over relay with this pin arrangement (not easily available in parts shops, google for V23134-E52-X84) or you can swap the sockets 30 and 86 in the relay socket and use the standard pinout relay (perhaps this is what the tech was trying to do?).
    Can somebody who has a 355 with Teves ABS confirm what pinout the green ABS relay has. If there is no green relay it is the relay with a diagram at its side like this:
  21. m.stojanovic
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    John, I just noticed hat the green relay you are holding has the "special" pin arrangement, like the one shown on the right picture above. Does your wiring to the connector for this relay match your green relay pinout? If it does, then check whether the new relay you bought has the same pinout as your green relay. Perhaps you can post pictures of the two relays showing the markings at their pins.
  22. Jpwulf
    Jpwulf Karting
    Sep 26, 2022
    81
    Oregon
    John Wulf
    The “special” green relay looks to be factory. Pulled out the harness to confirm wiring and it is wrapped in an old Ferrari sticker. So even though my car is a 355, it seems to be the same as the 348. With that said, the new relay I got does not match the stock green relay because of the special pin locations of 30 and 86.
    I did a test on the existing relays and you can hear them “click” like they are functioning, as well as tested them with an ohm meter and all seemed to test fine.
    Qavion likes this.
  23. Qavion
    14,601
    Ian Riddell
    Now the big question... where to go from here. The ABS fault light seemed pretty solid during their tests. Even after they erased the fault code by driving over 40kph, the fault seems to have resurfaced before the car reached 40kph (?) or did the light go out at 40kph and then resurface.
    "Performed all diag tests and checks again with similar results"
    What do they mean by "similar results". Did the 2.2 fault come back? Did the ABS stop working? Can you run the ECU test yourself?
    Experts: Are any of the hydraulic delivery valves replaceable or does the entire unit have to be replaced? Would a single valve failure cause a total ABS failure.
    When you did the battery test on the black relay, did you use the same pins as the other relays? The numbering system was completely different to the others (If so, let me know and I can add a note to my wiring diagrams). Thanks!
  24. Qavion
    14,601
    Ian Riddell
    How about shotgunning the system with some of the less expensive items (if there are any)? Since the ABS and Brake warning lights are coming on (hinting at a pressure issue), maybe replace the black pump relay?
    Do you have an aftermarket immobiliser system with a starter relay fitted? These have been known to disable the ABS system via the orange relay. The orange relay provides power to the ABS system when it is relaxed. Sometimes the relaxed contacts can be faulty.
  25. Jpwulf
    Jpwulf Karting
    Sep 26, 2022
    81
    Oregon
    John Wulf
    I was thinking the same. Replace the green special relay (or switch the wiring pin locations to make the one work I already have), and replace the black pump relay just to rule those out? Cheap options to rule those out.
    In regards to the immobilizer, the previous owner in fact DID install an aftermarket alarm. I had an independent shop remove the system, but no clue about the immobilizer issue or where to look for that…?
    Qavion likes this.
