355 throttle bodies on 348 project | Page 11 | FerrariChat
Discussion in '348/355' started by plugzit, Oct 22, 2006.
  1. cbstd
    cbstd Formula Junior
    Dec 24, 2003
    301
    Los Angeles
    I am coming very late to this discussion and I am not any kind of F car expert.
    In the world of Honda where I dwell, the three most important tools are the Air/Fuel ratio meter which gives a real time look at actual fuel mixture condition, the adjustable fuel pressure regulator which is the simplest method of effect mixture rich/lean and a fuel pressure guage. All three pieces are readily available through typical dealers for about $50 each. I am sure that these could be adapted for use in F cars.
    I have found even with what we think is a "massive" increase in air flow, a realtively small increase in fuel pressure through stock injectors will cure lean mixture.
    Scott (who works with Ernie)
  2. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    Yep. Wondering how it'll sit flush.
  3. plugzit
    plugzit F1 Veteran
    7,795
    Redondo Beach, CA
    Bruce Bogart
    The plan is to replace the air boxes with stacks and replace the MAFs with a MAP. Maybe run tall stacks thru a hole in the lid or short stacks like Andy. With the current setup 1.25" of lift is needed in front. With lid closed, you can't tell it unless you're looking for it.
  4. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    So in matching the 2.5 tables to the 2.7 tables I discovered something cool.
    Motronic 2.5 and 2.7 have a table from idle to redline for setting how much time the coils charge. Heckofa variable to be able to control. Want a bit more voltage? M2.5 and 2.7 are *not* tapped out in OEM trim.
    Oh, Plugzit will be getting Stooge v0.3 tomorrow morning. He can tell everyone more of what that chip will do.
  5. plugzit
    plugzit F1 Veteran
    7,795
    Redondo Beach, CA
    Bruce Bogart
    You, sir, are one fine individual.
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Aw, shucks! Thanks, Bruce. Stooges rule!
  7. fatbillybob
    Aug 10, 2002
    29,277
    socal
    Now you are talking! If memeory serves that's only 65hp less than Goth 355 @ the wheels! Looks like 348 guys may not need no stinking crappy 5 valve heads with lamo guides????
  8. fatbillybob
    Aug 10, 2002
    29,277
    socal
    ND,
    What will more voltage do at the coils assuming the mixture is burning fine? Don't you only need more volts if the amount of fuel is increase quite a bit?
  9. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Yes, Stooges rule!
    Ya gotta just love the Brotherhood.
  10. plugzit
    plugzit F1 Veteran
    7,795
    Redondo Beach, CA
    Bruce Bogart
    Yes, the Brotherhood is strong and stooges.........well, they're stooges. :)
  11. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Right. It would only make a small increase in burn efficiency at the expense of shorter coil and plug wire lifespan.
    ...but...it's there.
    We *could* bump it up if we wanted (say, for a track day chip). No one says that you have to drive all of the time on the same set of chips.
  12. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    You know what we really need to get ahold of? A set of 355 2.7 chips. Then we can see what the 355 is doing through out the rpm range. I think that will help take a whole lot of the guess work out of this.
  13. plugzit
    plugzit F1 Veteran
    7,795
    Redondo Beach, CA
    Bruce Bogart
    Just posted "where's Gothspeed"? I'll bet he'll help!
    Who's guessing? Aren't we simply taking a systematic approach to a complex problem with certain waypoints in building a matrix for successful results?
  14. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Is Goth's car a '95?
  15. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    A good idea, but then we'd have to account for the different fuel pressure of the 355, the different fuel injectors of the 355, and the different displacement...plus the different fuel mapping tables.
    Of course, I say all of that and watch the final Stooge chip be nearly identical to a 2.7 355 chip like you said all along!
    Life has a sense of humor, I guess!
  16. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Well as soon as we can hog tie Goth, and remove chips out of his 355, we'll find out. :D
  17. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Works for me! I'd truly like to compare the maps. I'd graph them and post them here just for the heck of it.
    Oh, I just need one 355 chip, by the way. They are identical between ECUs. I can scan it and overnight it back. Same maps, so no need to scan both chips from the same car.
    A 348 non-spider 2.7 chip would also be nice to have/scan. Say, something between 1990-1993.
    Any 348 Competizione LM owners want to let me scan a chip for comparisons and graphing?!
  18. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    I can burn you a couple if you'd like.
    JM
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,815
    The twilight zone
    The charge time is about getting the coil to saturation, once the coil is saturated, no additional time will improve the spark voltage/energy. In fact, extra time will actually hurt the spark a bit because the coil will heat up and resistance of the wire will go up. Probably not a good idea to mess with.
  20. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    From the data, the Motronic 2.5 and 2.7 OEM coil charge table varies in duration based on battery/system voltage and RPM. Lower RPMs get a *shorter* charging time per the OEM table.
    While lower system voltage causes the table to give a longer charging time.
    Where it gets interesting is that the table does not max out the charging time for normal and high voltage conditions at high RPMs.
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,815
    The twilight zone
    That does seem odd. The scheme the aftermarket ECUs seem to use is simply a fixed time, which makes sense…although I’ve never put a scope on the signal, they may very well be doing more than the inputs lead me to believe. Strange, I wonder what the reasoning could be……
    It looks like the tune is getting close, v3 may be a winner.
  22. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #272 No Doubt, Jan 11, 2007
    Right. Here's a screen shot of the coil charging table. Higher hex values mean longer coil charge times. Notice the E4 values for the low voltage, high RPM conditions...and compare that to the smaller values when voltage is normal or high when the RPMs are high.
    (RPMs on left going vertically, Voltage values on top going horizontally)
  23. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,815
    The twilight zone
    I’m guessing they spec’d a coil with pretty low resistance in the primary winding so it could generate a good spark even in a low voltage condition. But at higher voltage, it just flows too much current and gets too hot. They reduce the time trying to achieve basically constant charge.
  24. plugzit
    plugzit F1 Veteran
    7,795
    Redondo Beach, CA
    Bruce Bogart
    Stooge v3
    260rwhp on FBB's g-meter
  25. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Cool! The new blank chips should be in by the time I get back from skiing, and it will be *easy* to bump up the hp from here on out.
    OEM=145 rwhp
    V0.1=205 rwhp
    V0.2=235 rwhp
    V0.3=260 rwhp
    We've got *lots* of room to bump up the t3 table (that's what gave you the +25 rwhp bump on V0.3 from V0.2).
    Life is good.
    Still getting lean symptoms, I presume?!
