355 throttle bodies on 348 project | Page 21 | FerrariChat
Discussion in '348/355' started by plugzit, Oct 22, 2006.
  1. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    Okay, so it's time to begin Stage II, putting the ram tubes on the throttle bodies and getting rid of those bulky airboxes and intake hoses along with the MAF sensors. I drove down to Hilborn Fuel Injection this morning, as they seem to be the only ones who make this size-1 13/16"-45mm-tube. As it turns out, Hilborn is a great group of people. The sales & tech guy, Ernie Peck, is an enthusiast, and had some stacks custom made at 10" with a flange on the bottom so I can use the stock 355 clamps. Nice stainless steel. He introduced me to their technical director, Don Enriquez (you old guys may know that name-he's in the NHRA hall of Fame). If you're considering a throttle body change, talk to Ernie. They have some new products and products in development that will blow your mind, and he'll work with you. My next step is to work with IDA performance on the east coast. He's going to wire up a converter box (SMT-6) to change the signal from the map to talk to the brain like it's a maf. I'll follow up when that's begun.
  2. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Way to go Bruce....can't go wrong with Hilborn......really interested in the IDA setup..please keep me informed as you know I'm heading in the same direction with eliminating the AFM's.
  3. fatbillybob
    Aug 10, 2002
    29,431
    socal
    Bruce...we need pictures!
  4. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Do you think Hillborn can do the custom airboxes for a 2 tb setup like the 360's?
  5. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    Right on Plugs, thanks for the up date. I hope you're keeping this at Stooge prices?
  6. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    #506 gothspeed, Apr 26, 2007
    HKS makes a MAF 'omitter' :
    Online Catalog > Fuel Management > VPC (Vein Pressure Converter) >
    VPC (Vein Pressure Converter) (more)
    The HKS VPC is a fuel management device that is designed to physically and electronically replace the OEM air metering devices for improved air flow and precise fuel delivery control. OEM air metering devices, such as Air Flow Meters (Flapper/Plunger types) and Air Mass Sensors (Hot wire / Karmen Vortex types) measure the amount of air flowing into the intake manifold in order to properly control fuel enrichment levels. Aside from offering no adjustment or reprogramming options to take advantage of dramatically higher amounts of airflow or larger fuel injectors, the OEM air meter also represents a significant restriction to the intake system. To overcome this restriction, the VPC physically removes the OEM air meter to dramatically improve airflow capacity and converts the system to what is referred to as a speed density system.
    Available at:
    Toysport
    15626 Inglewood Ave.
    Lawndale, CA 90260
    (310) 643-6442 Phone
    www.toysport.com
  7. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    You betcha! It'll be stooge time soon when I have all the parts accumulated. Dan wants us to do it at his shop, which sounds good to me. Big fridge, couches and chairs.
    I'm there today! Thanks, Goth!
  8. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    I tried to find the 'closest' retailer to you!! :D
  9. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Thanks OZ......I'm wondering what the difference is going to be between HKS and IDA setups...hopefully one of these will be an easy install? Either way I am excited to see Bruce persueing this at full speed....348 and 355 guys wanting increased performance will hopefully see improved results by this mod.
  10. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    I would be nice to have the engine not suck through a straw anymore :eek: !
  11. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Good thing we're not running liquid thru the AFM...it would be like a stopped up toilet....lol
  12. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    Unfortunately, HKS has discontinued this product. Maybe I can find one on ebay. More research......
  13. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    :eek: !!
    Go plugzit!!
  14. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    +1....Bruce is like a bloodhound.....
  15. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Bruce check this out and see if there is any potential for your application....
    linkecu.com
  16. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Also look at
    turboxs.com/UTEC.htm
  17. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Bruce...disregard this......don't see any application for an 8cyl, but is good reading material..lol
  18. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    #518 plugzit, Apr 27, 2007
    Thanks, guys. I'll look into these right away. Meanwhile, I couldn't resist the temptation to mock it up. Here are some photos. It should look a lot better when the wiring is cleaned up. I'm deciding whether to polish or paint the stainless ram tubes. They's stick out about 3". I may build a scoop over them pointing backwards. I'm leaning toward plexi for that. Tuning note: After lengthy scientific discussions and consultations with aerodynamicists and calculations regarding track design, gear selection, torque curves, air speed and mass, heimholz effect, lies and war stories, alternative ratios and massive amounts of beer it was decided that the length of the ram tubes looked really good like this.
  19. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    What color are you going to paint the wood??....lol
    Say it was mostly the beer that determined the height...very very scientific..lol.
    I'd like to see how this length looks with the hood closed....I like the air cleaners....atleast they will keep out large insects,rodents, and leaves.
  20. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    I'll have you know that wood is the finest Italian Olive tree wood CNC machined to exacting Ferrari tolerances custom by the local dealer for only $723.95! Unfortunately, its' use will not be necessary with the stacks on-it was clearance for the air boxes.
    They'll stick out about 3".
    Some people prefer 1 micron filters. I'm more of a 1mm kind of guy.
  21. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Bruce I believe the price...........
    3" projection will look awesome....either polished or matte black....can't wait to see the plexi cover.
  22. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Bruce you are a man of ability, accomplishment, aestheticism, art, class, enlightenment and erudition :eek: .
    Meaning, your choice in stack design and dimensions are impecable :) :) !!!
  23. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    OZ, you've been drinking under the shade tree with Bruce toooo many times for your opinion to be objective...lol
  24. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Who me.............???................ I don't drink anymore :eek: ...............or any less :p!!
  25. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    I had a case of aesthetism once, but I got rid of it with some penecillin and blue ointment.
    Yes, I've been told I've got a lot of class-trouble is, it's all low. :)
