355 throttle bodies on 348 project | Page 22 | FerrariChat
Discussion in '348/355' started by plugzit, Oct 22, 2006.
  1. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    :p LOL :p
  2. group77racing
    group77racing Formula Junior
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    don't forget our cars are 2, 4 cylinder engines sharing a common block.
  3. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Dave you are right....easy to forget that in the heat of frustation.
  4. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    So do any of the 8 cylinders 'fire' at the same time??
  5. WilyB
    WilyB F1 Rookie
    4,289
    AZ
    For really good engine management systems, I would suggest you visit www.haltech.com
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Nope. Haltech can't even come close to what Motronic 2.7 can do.
    M2.7 is completely programmable. Coil charge time. Ignition advance. 255x255 fuel air maps (well, limited by chip storage). Full OEM error detection and electronic monitoring of all electronic components.
    Plus, M2.7 has a watchdog. The system physically *can't* remain in an error condition for more than a tenth of a second thanks to the M2.7 watchdog. What's Haltech going to do if it encounters a programming error?! You want your engine computer to be "hung" while you are revving to 7500 RPMs?! It needs a watchdog timer.
    What's Haltech going to do if a cat overheats? I'll tell you what...Haltech is going to let your car burn to the ground.
    Not Motronic 2.7. M2.7 is going to shut down a bank of cylinders until the offending catalytic converter has cooled off. You're still driving, but safely at half power.
  7. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    It is called "waste spark", when one cylinder is firing on the comression stroke there is always another that is halfway through its 4 cycles, and will fire at the top of the exhaust stroke.
    1-5-3-7-4-8-2-6
    when 1 is firing, 4 is on the exhaust stroke, etc.
    And now back out to the garage to finish mocking up the new cats, headers recieved last night and installed this morning.
    JM
  8. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    Speaking of which, have you had your thing of beauty running yet?
  9. fatbillybob
    Aug 10, 2002
    29,433
    socal
    #534 fatbillybob, Apr 29, 2007
  10. fatbillybob
    Aug 10, 2002
    29,433
    socal
    Is there a way to upload a word .doc file so it just appears when you see it on fchat without having to click on it and have your computer open MS word?
  11. chrisx666
    chrisx666 Formula Junior
    Dec 6, 2004
    562
    YorkshireUK
    Chris B
    #536 chrisx666, Apr 30, 2007
  12. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    Finally, the air management system is on the way. Two little boxes from Ida Automotive in Morgantown, NJ. These will allow on-the-fly changes to the a/f ratio, but hopefully not necessary after the dyno time to tune the motor! They're supposed to be here Tuesday! I'm stoked! Finally, the stacks go on and those big, heavy, and complicated air boxes come off! I've got about 5 days to mount the courage to cut a hole in my bonnet! (To match the hole in my head)
  13. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    Interesting. Is that related to Unichip, also from South Africa?
    I have seen people take the multiple pdf's of the wiring diagrams, and bring them to Kinkos to make one giant poster. That might be cool and useful for you. There are guys who even color them in and sell them on ebay, but I have never seen one for a Ferrari.
    Jay
  14. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Bruuuce!!! No need to cut a hole in the bonnet!!! One can just make a replacement piece for the front part of the lid!! Say maybe out of a nice clear material (lexan :rolleyes: ), to show off the entire motor while you are at it :D :D!!!!
  15. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    If you take a close look at the construction of the bonnet, you'll see it's not as easy as that. The front piece is formed with the frame, so would require quite a bit of cutting to remove. If, God forbid, I ever need to return it to stock, I can simply put a piece of Ferrari glass (Lexan) in the hole and it'll show off the stock plenums nicely.
  16. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    They're in New Jersey. I'm not sure about the pdf's but sounds like neat art.
  17. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Bruce that is great news....can't wait to see it installed and running....have you found a suitable rear wing for the in-flight testing....are you staying with the stock fuel injectors?
  18. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    I'll probably use the APR Performance GTC300 wing. 67" wide, real good airflow characteristics. Something like 240lbs downforce at 120, <19lbs drag. I've got some 24lb. Ford 5.0 injectors in there now. Stock is around 16lbs, 355s 19 or so. Hoping I'll need to go to some 32s!-Group77, IIRC, says I'll need them to make 400hp or so, though I probably won't be making that much yet. Looks like I'm gonna have to do VCT for that :). Is my sanity in question???? What are the voices in my head saying????
  19. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Just reviewed this thread after a couple of weeks -- and I thought I was over-the-top.
    Just one data point - if those are the air cleaner elements with the white fiber filter element that you plan to use on the velocity stacks, I knew of an engine dyno's Bizzarini V-8 where the difference between using those filters and open 45mm velocity stacks was close to 80 - 100 hp. They may not flow as well as hoped - be sure to dyno with them on and off.
    Good luck - this is quite fascinating!! I'm really looking forward to a DynoJet rwhp if possible.
    Back to my 1940s technology and simple basic modifications... :)
  20. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    What is this I hear about you going MAF-less???? Share the wealth pluzit :)!!!
    BTW the voices in your head are right :D :D!!!
  21. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    Electronics get here tomorrow. The MAFs go out to pasture shortly thereafter!
  22. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Duuuuuuuuuude!!!!! Awesome!!!!!!!!! Can I help :)???
  23. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    Not really much here-it's just that what used to be a simple carb change got complicated in the electronic age-yep, computers are gonna make our lives so much simpler.....not!
    I remember Bizzarini from the 60s. Italian body with Chevy motor. Pretty. Didn't he also try to do a F1 car? Filters are little screens with foam just to keep out rocks and cigarette butts. I'll dyno without for sure.
    40s technology.....a flathead Ferrari? :) Oooooh, I have an idea. Wouldn't it be cool to do a 3xx with a flattie? Can you imagine the retching at the concours when they opened the hood? Iwannadoit.
  24. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    PM me your # again. I'll call!
  25. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    :D !!!!!
