355 work well but not powerfull | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by fana355france, Jul 19, 2007.
  1. eric355
    eric355 Formula 3
    BANNED Silver Subscribed
    Nov 30, 2005
    1,224
    Toulouse (France)
    Eric DECOUX
    It seems OK. On mine, black is for exhaust valve and blue is for air injection valve.
  2. fana355france
    fana355france Formula Junior
    284
    France
    nicolas
    I tested a minute ago the black is for bypass Im ok.
  3. fana355france
    284
    France
    nicolas
    Sorry Eric I sent you an email I did not saw it was you on the forum trying to help me !
    Merci eric
    Nico
  4. fana355france
    284
    France
    nicolas
    I made some more test.
    both solenoid are ok
    tested ohm resistance between pin 21/27 on the 5/8 ecu, it is same like the solenoid resistor.
    So no wire cut too...
    Can you tell me what parameters are needed for the ecu to decide to open the valve ? like this I could check others sensors or else...
    thanks nico
  5. fana355france
    284
    France
    nicolas
    Found problem:
    Valve did not work because of errors in the ecu
    whater temp sensor error
    solenoid air relay error
    made the self diagnostic, removed the codes(put a video on this forum), cleaned wires and everything is ok.
    Thanks for help.
    nico
  6. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Did you fix the water temp sensor issue?? Mine had a similar problem and the thermal switch on top of the LH radiator was bad and not switching on until about 215 degrees or so. The thermal switch should trigger the left hand radiator fan at 190 degrees.
  7. fana355france
    284
    France
    nicolas
    No infact I did not need to change it because it was my fault...I had 2 plug wire damaged and the car was running bad...before to find the cause I have done so much test that i introduced error codes in ecu !
    now it is ok.
    bye and many thanks to this forum
  8. 355spider96
    355spider96 Karting
    Mar 28, 2007
    103
    So if you have other codes coming up then the ecu will not allow the bypass valve to open???
