355F1 Clutch Position Sensor | FerrariChat
Discussion in '348/355' started by Steve355F1, Nov 30, 2017.
  1. Steve355F1
    Steve355F1 F1 World Champ
    Aug 26, 2011
    17,175
    Adelaide, South Aust
    Steve
    Hi All,
    In trying to solve the strange issue of the clutch overheat beeping after the car has warmed up to temp (described in another thread), I have now discovered that there seems to be two different clutch position sensors listed for the 355F1.
    On Eurospares, there is. part no. 171307 which is listed as “early type”, and then part number 244801 which presumably is a later type.
    My question is, given that my car is one of the first 355F1s, should this sensor have been replaced with the early type or wouldn’t it matter?
    This problem of the strange buzzing only started after my sensor was replaced at the dealer, and I see they have replaced it with 244801. Is it possible that they should have used 171307?
    Is there a way to find out which one would be correct for my cars build number?
    Thanks.
  2. WATSON
    23,847
    WI
    Perhaps a call to Daniel at Ricambi? He may have some guidance.
  3. Steve355F1
    Aug 26, 2011
    17,175
    Steve
    Thanks. I’ll do that if no-one has the answer quickly.
    Just thought there might be something obvious along the lines of “up to build no. x use part y” etc.
  4. Qavion
    Qavion F1 World Champ
    14,445
    Ian Riddell
    On the Ricambi site, it says that the 171307 has been superceded by P/N 182311. When you go to that part number, it says it has been superceded by part number 244801.
    Sounds like they should be the same.
  5. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    I have one of these taken off of a 99 F1 trans, I parted the trans out.
    I'll o a better price than anyone else that may have used ones for sale.
    If interested let me know.
  6. Steve355F1
    Aug 26, 2011
    17,175
    Steve
    Thanks Ian. Seems like they installed the correct part.
    I wonder if there is any way to “bench test” these sensors before putting them in the car to ensure they are working correctly?
    Thanks. Will chat to my mechanic when he gets back next week and let you know.
    I may well be interested at the right price.
    phrogs likes this.
