355F1 - Oil Temp Gauge / Clock Swap | Page 3 | FerrariChat
Discussion in '348/355' started by AVMotorsport, Sep 9, 2012.
  1. Rifledriver
    37,299
    Good idea. I never understood why those idiots sacrificed the oil temp gauge on the F1 car when nearly every $45 radio has a built in clock if anyone even cares about the time.
  2. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Nice work
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hey - that gauge panel looks pretty good ;) :)
  4. WATSON
    24,025
    WI
    I have a clock on my wrist, phone & radio....why do I need one in the damn dash, right? Wonder why Ferrari did that???
    What a great tool this forum is. Yes, McJoe (hehe), the panel looks great ;) Thanks, you did a great job.
    I really do wonder how a guy could own a 355 and not be connected with the resources and people here.
    Thanks.
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Thank you for the business and trust. It's also nice to see so many folks here working on their cars and improving them in so many way.
  6. AVMotorsport
    AVMotorsport Formula Junior
    255
    SoCal
    Alex V
    So, is your gauge reading correctly now? Did you end up changing the sensor?
    Looks great!
  7. WATSON
    24,025
    WI
    For reasons undetermined, the gauge reset after a couple of cycles and appears to be working. I suspect that sensor is simply old and intermittent.
    The pic of my dash was during a run we did on Sunday. Cruising down the highway it was really nice to see that oil temp instead of the time. :)
    Regardless, I have a new sensor I bought from Ricambi. Next oil change and it'll go in.
  8. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    nice! ... that arrangement makes more sense ..... :)
  9. 601
    601 Karting
    Dec 19, 2010
    223
    California
    My right hand on the steering wheel blocks my view of the left most gauge, which is oil pressure on the F1. I like to be able to see oil pressure at a glance, so took the opportunity to swap the oil pressure and fuel gauges when this mod was done.
    This may vary for others depending on seating position and whether the smaller 360 steering wheel is used, so best to plan the gauge arrangement before taking the cluster apart.
  10. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,033
    NE FL
    Ken
    #60 kenneyd, May 1, 2016
  11. WATSON
    24,025
    WI
    #61 WATSON, May 1, 2016
    Winner! :) That's where I was heading...but I gave up on that mess!
    I will officially buy you a beer or glass of Cask 23 if we ever meet up. Your call!
    Nice job man....
    Curious. Does that wire just terminate there, or carry on? I mean really, it just stops there?
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Great job!!
  13. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,033
    NE FL
    Ken
    IT stops right there, no wire on the other side. I suppose the harness from the engine to that point is the same F1 and gated, and past that point its version specific.
    I had to run wires from my oil pressure gauge to the dash cluster when i removed my F1 selector for the manual version cluster which has water temp/oil pressure. I did this swap to complete my F1 to gated swap but still left everything marked with instructions on how to go back.
  14. WATSON
    24,025
    WI
    While we all suspected it was the same harness, it is great to fully understand that the wire simply terminates in the block. Had it carried on to an ECU somewhere was a constant question for me.
    Keep Calm & Carry On! :)
  15. AVMotorsport
    255
    SoCal
    Alex V
    Excellent find! Mystery solved!
  16. Rothbauer_Racing
    Rothbauer_Racing Formula Junior
    Jan 11, 2007
    442
    Röthbauer GmbH
    Great Thread! I remember wanting to do this in the past. The 355F1's has to have a oil temp as all modern cars need it for the master ECU. Why did Ferrari choose not to display the gauge?
    An OBD-II scanner should pick up the oil temp reading? I will have to check. I am planning a new GPS data logger in the near future. See below.
    https://www.pegasusautoracing.com/productdetails.asp?RecID=11464
    Till then I'm joining in on this mod for now!
  17. WATSON
    24,025
    WI
    Just confirmed is the fact that the lead form the oil tank sending unit terminates at the end of the harness. It does not feed an ECU and as a result can not be used in any OBDII codes.
    The 355 F1 car is running blind on oil temp...both electronically and optically (until you install the gauge anyway).
  18. Skippr1999
    Skippr1999 F1 Rookie
    4,570
    Not being an electrician, do you pull the brown wire out of the white plug and then crimp a extension wire up to the gauge area to make the final connection ?
  19. 601
    601 Karting
    Dec 19, 2010
    223
    California
    I wouldn't do that. The easy way is to tap the wire. The right way is to attach your extension wire to the other end of the connector.
  20. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Posi-lock and Molex Permaseal Connectors
  21. 601
    601 Karting
    Dec 19, 2010
    223
    California
    I don't think it's common for ECUs to consider oil temp. Perhaps you're thinking coolant temp, for which the ECU in the 355 has its own temp sensor independent of the sensor used to feed the gauge.
    In any case, the 355 does not support the standard OBD2 PID for oil temp. And I highly doubt it uses a custom PID, considering that later F1 builds don't even have the temp sensor in the oil tank anymore. Seeing that you have a 1999, you would do this mod with thermistor replacing drain plug, but instead (or in addition) of installing the oil temp gauge you would connect the wire to an analog input on your data logger.
  22. WATSON
    24,025
    WI
    Yup. That was my plan had I found the wire in the terminal block. New connector & wire picks up where the existing one stopped. Total OEM look....still kinda wish I did it that way... Running a new wire is equally effective.
  23. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,033
    NE FL
    Ken
    I removed the pin from the connector completely intact and soldered a brown wire to it and covered it with heat shrink tubing. That wire runs to the connector at the harness where is can disconnect with the other gauges.
    Done!
    Sent from my LGLS990 using Tapatalk
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Excellent - that's the way to do it :)
  25. WATSON
    24,025
    WI
    Great! But do I see:
    Clock - Fuel - Oil Temp?
    Where did the oil pressure gauge go?
