355F1 - Oil Temp Gauge / Clock Swap | Page 4 | FerrariChat
Discussion in '348/355' started by AVMotorsport, Sep 9, 2012.
  1. 601
    601 Karting
    Dec 19, 2010
    223
    California
    To the main instrument cluster, due to manual conversion as evidenced by the shift knob in the photo.
    Would it not have been possible to keep the gear indicator or is that a casualty of the conversion?
  2. WATSON
    23,929
    WI
    That's right. I forgot he converted it to a 6 speed.
    Hey. According to Hagerty, he just added $30,000 of value to his car! Nice work.
    Carry on :)
  3. AVMotorsport
    AVMotorsport Formula Junior
    255
    SoCal
    Alex V
    Do you mind starting another thread, or have a link to a thread, describing that F1 to manual stick conversion you performed on your car? If you could mention the parts required, amount of labor involved, and overall cost, that would be great. I probably won't do it myself, but it is good to know that it is possible. TIA.
    I will have to redo the wiring of my gauge install, now that we found the correct wire to the gauge! It will be more "Factory correct!"
    Cheers
  4. 601
    601 Karting
    Dec 19, 2010
    223
    California
    I have not done the conversion, just noticed the shift knob in kenneyd's photo. Hope he will respond.
  5. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,028
    NE FL
    Ken
    The gear indicator always showed "-" so it didnt follow the manual shifting (I do have my F! TCU unplugged however). I wanted my car to match a factory gated car in every way so i swapped the F1 part of the cluster for the water/oil pressure gauge.
    Sweet! Hagerty is comical
    I've debated this, but internet scrutiny from elitist is not worth my time.
    I will say its actually very simply and i could reverse it in a few hours.
    Im happy to help anyone looking to do this.
  6. 601
    601 Karting
    Dec 19, 2010
    223
    California
    That is real pioneering work, just as Alex did with the oil temp gauge. If this thread is any indication, a lot of people would really appreciate it.
  7. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    I have some advice for you; Don't be discouraged by the internet elitists, but rather be encouraged by the genuinely inquiring minds ;)
  8. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,028
    NE FL
    Ken
    #83 kenneyd, May 9, 2016
    One more thing to add.
    Maybe I am lazy or impatient lol... but I'd hope my efforts are more of a "keep-it-simple-stupid" I experimented with the temperature sensor gasket.
    Yes the factory plug is flat with a copper crush gasket and the oil temp is tapered and does not have a gasket of any kind according to the parts diagram.
    Most of my other cars have had a simple o-ring type washer and so i went to autozone and picked up a M14 653336 oil drain plug gaskets and used the rubber one and installed it. (it is a sung fit so i had to spin the washer onto the plug.)
    I installed it snug, but not tight, drove it until the oil was hot and checked. No seepage what-so-ever.
    Please, If anyone has concerns over this please tell me why? otherwise, i think this is an simple way to do this swap that mimics other manufactures OEM drain plugs.
    P.S. I also did this with a full oil tank since i recently had and oil change and did not want to wait. It wasn't bad if you're quick. Just an arm bath and a few paper towels for the floor. I didnt even notice any change in the oil level.
  9. shlokserai
    shlokserai Rookie
    Oct 15, 2017
    1
  10. Qavion
    Qavion F1 World Champ
    14,533
    Ian Riddell
  11. Qavion
    14,533
    Ian Riddell
    Your oil pressure is working, so it's unlikely it's a power issue or instrument plug/connector issue. Does the instrument background lighting work?
    shlokserai likes this.
  12. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,028
    NE FL
    Ken
    @shlokserai
    I would start as the basics.
    -Check that the sensor is even plugged in
    -check the continuity of the wire from sensor to gauge.
    -Test the resistance of the sensor
    -test the gauge by installing a resistor
    I suspect just a lose connection or bad sensor.
    Qavion likes this.
  13. Qavion
    14,533
    Ian Riddell
    I just checked the sensor on my car and it's visible, but I couldn't get my hands anywhere near it. You would have to remove the coverplate in the engine "V" and lift up the coolant tank. Because the sensor (switch/transmitter) connector is hard to get to, you could check the resistance of the sensor by accessing the large rectangular connector behind the rear left hand suspension strut. If you tell me which car you have, I can post a wiring diagram and tell you which pins/sockets to check.
    I assume you have a digital multimeter and some basic tools, although you'll need a 3.5mm Allen wrench to take off the engine bay side cover plate.
    Hopefully this will not be your one and only message post on FChat.
  14. Qavion
    14,533
    Ian Riddell
    #89 Qavion, Nov 18, 2019
  15. WATSON
    23,929
    WI
    It's rough getting old.
    I literally just answered my own question from a post I made 7 years ago.
    Qavion likes this.
  16. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Ha ha ha
    I remember that as I was going to install one using your method but we squashed it.
    I agree on the old thing
