355F1 Relief Valve | FerrariChat
355F1 Relief Valve
Discussion in '348/355' started by JazP, Jun 20, 2019.
  1. JazP
    JazP Karting
    Feb 23, 2013
    52
    I suspect that the pressure relief valve of my F1 unit is bad. Does anybody know where it is located?
    Looking at the unit I find two screws: One at the top (A) and another next to the solenoids (B). See attached picture. Is one of them the pressure relief?
    Thanks for your help!
  2. JazP
    JazP Karting
    Feb 23, 2013
    52
    No ideas?
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Why do you suspect the pressure relief?
    Whatare the symptoms and whats happening with the system?
  4. Qavion
    Qavion F1 World Champ
    14,342
    Ian Riddell
    Looking at the hydraulic schematic in the workshop manual (page D20), the relief valve is towards the top end of the unit, in the middle. If you had to guess, "A" would be the likely one.
    What's that circular item below the "A" in your photo?
    JazP likes this.
  5. JazP
    JazP Karting
    Feb 23, 2013
    52
    Loss of pressure in idle (i.e. no solenoids actuated). The pressure releases through the return line, so its not the check valve.
    That was an educated guess and you're absolutely right! The screw contains a spring loaded ball, which acts as the relief valve. You can adjust it by turning the inner part. The outer part (i.e. the screw nut) is just there to hold things in place.
    Moreover the screw is also part of a check valve: the top of the screw compresses another spring which presses against another ball.
    Well, I don't know the english term. Its there to seal the cross hole which was necessary for manufacturing purposes.
    Qavion likes this.
  6. JazP
    JazP Karting
    Feb 23, 2013
    52
    Oh and just to answer that as well: B is there for air bleeding EV1 and EV2.
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Is your accumulator good?
    Is it over 10 years old?
    How long have you owned the car? If atleast 10 years have you ever notice the hydrauic oil getting a bit creamy looking or foaming?
    WATSON likes this.
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Does loss of pressure at idle mean it works when engine is reved up?
