355F1 won't engage. | FerrariChat
355F1 won't engage.
Discussion in 'Technical Q&A' started by dusk, Mar 2, 2008.
  1. dusk
    dusk Formula Junior
    Nov 8, 2005
    427
    Brisbane
    Pete
    I cannot get a gear in my 355F1. When I try and select 1st or reverse I can hear the actuator kick in but it stays in neutral.
    I have checked the gear oil level and fuses and all are O.K. Any ideas?
    Cheers,
    Dusk.
  2. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,974
    MD and NE
    Robbie
    Make sure the rear bonnet is closed and latched, the F1 will not engage if it is open--- also the F1 will not engage unless the drivers door is secured..
  3. PAP 348
    Dec 10, 2005
    100,231
    Mount Isa, Australia
    Pap
    +2!! :):)
  4. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Might consider checking/bleeding clutch fluid.
  5. dusk
    dusk Formula Junior
    Nov 8, 2005
    427
    Brisbane
    Pete
    Checked all above still no go. I just had a new clutch fitted and have only done 126klms since then. This morning took it out and it would not change from 2nd to 3rd returned home and parked it. Now can't get anything.
    Dusk.
  6. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    Ck your F1 pump's reservoir fluid level
  7. PAP 348
    Dec 10, 2005
    100,231
    Pap
    Who fitted the clutch Pete?? Yourself? :):)
  8. dusk
    dusk Formula Junior
    Nov 8, 2005
    427
    Brisbane
    Pete
    It's on the marks.
    Thanks,
    Dusk
  9. dusk
    dusk Formula Junior
    Nov 8, 2005
    427
    Brisbane
    Pete
    The local Dealer Pap, if I'd fitted it the bloody thing would work.
  10. PAP 348
    Dec 10, 2005
    100,231
    Pap
    :p:p
    Well, they have obviously f*cked up! :D:D
    Call them in the morning and tell them to sort it out mate!! Dont make me fly to Brisbane and inspect it myself. :eek::eek:
  11. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    I am curous if this could be caused by the installer forgot the lubricate the input shaft / spline. This happens a lot, and after awhile the input shaft would rust and the clutch would not float freely on the input shaft and cause shifting issues. But when that happens you usually would experience car launches forward when you are starting the car.
  12. dusk
    dusk Formula Junior
    Nov 8, 2005
    427
    Brisbane
    Pete
    Well thanks for all your help, nothing worked, I suspect a sensor somewhere has malfunctioned. So its back to the work shop.
    Best,
    Dusk.
  13. PAP 348
    Dec 10, 2005
    100,231
    Pap
    Please let us know how you get along Pete. :):)
    Cheers mate and good luck with it. :):)
  14. 285ferrari
    Sponsor
    Sep 11, 2004
    20,974
    MD and NE
    Robbie
    Hold in the UP paddle for about 30 seconds and see if it engages...
  15. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,830
    Cerritos, CA.
    Pete, check the fuse or the relay behind the Left side seat, and or the Front Right fuse box ender the dash, there's a fuse/relay that are related to the gearbox,
    if this fuse is blown it will affect your shifting. Not sure which fuse for the trans. but just look for something blown in both fuse blocks.
  16. dusk
    dusk Formula Junior
    Nov 8, 2005
    427
    Brisbane
    Pete
    O.K. Thanks for all your suggestions, the problem turned out to be caused by a faulty TCU. (Computer). The unit was replaced and now everything is working as it should.(Touch wood).
    The dealer had no Idea what might have caused the problem and stated it was the first time he had experienced this with a 355.
    I did have the car on a trickle charger when we had a power surge that tripped all the circuit breakers in the house. When I mentioned that as a possible cause he said he thought not.
  17. PAP 348
    Dec 10, 2005
    100,231
    Pap
    Cool cool. Fair enough mate. :):)
    I also dont think the power surge was an issue. Just one of those things me thinks. :):)
    Thanks for updating us Pete. :):)
