355gts power window switches | FerrariChat
Discussion in 'Technical Q&A' started by marioz, Oct 26, 2004.
  1. marioz
    marioz Formula 3
    Nov 21, 2003
    2,025
    Cedar Mills,Ontario
    Mario
    The power window icons on the window switches stay lit all the time on my 355gts. Does anyone have the same situation? Somehow this does not seem normal & this is with the key off & lights off. Have only had the car for a month. ANY INFO IS APPRECIATED.
  2. Robertb
    Robertb Formula 3
    Nov 19, 2003
    1,331
    South Oxfordshire, U
    Robert
    Not noticed if mine stay on...
    However, you can use the windows from the drivers side with the ignition off- perhaps its something to do with that.
    Robert.
  3. Merdav
    Merdav Formula Junior
    Apr 11, 2004
    980
    Are you sure they dont go off after about 30 seconds after you remove the key AND close the door, I believe they are wired into the cabin timer relay, and turn off the same time the overhead light would.
  4. marioz
    marioz Formula 3
    Nov 21, 2003
    2,025
    Cedar Mills,Ontario
    Mario
    ROBERT-my windows work for 2 minutes (as stated in manual) after key is turned off.
    MICHAEL-the cabin lights works as you mentioned but the window icons stay on.
    The problem I am having is that if I don't drive the car for 3 days the battery goed dead. I found a draw in the window circuit & in my radio/cd changer circuit. I removed fuses in both & battery seems to hold charge. I put in window fuses last night & I am waiting to see if battery voltage drops.
    PS-YES I KNOW I SHOULD DRIVE THE CAR-BUT THAT IS NOT ALWAYS POSSIBLE-LIFE GETS IN THE WAY.
  5. marioz
    marioz Formula 3
    Nov 21, 2003
    2,025
    Cedar Mills,Ontario
    Mario
    I CHECKED BATTERY VOLTAGE & FOUND VOLTAGE DROPS .15 VOLTS EACH DAY WITH POWER WINDOW FUSES INSTALLED. I AM CONVINCED NOW THAT THERE IS A PROBLEM WITH WINDOW ICONS STAYING LIT. DOES ANYONE KNOW HOW THIS SYSTEM WORKS OR HAVE A WIRING DIAGRAM FOR THIS CIRCUIT. ALL FERRARI CAN SAY IS THAT THEY WOULD HAVE TO LOOK AT IT-AT A COSTLY PRICE I'M SURE.
