360 AC Problem, High Low Side & Low High Side | Page 4 | FerrariChat
Discussion in '360/430' started by TheRealFlyingBear, Jul 20, 2020.
  1. TheRealFlyingBear
    Apr 27, 2020
    152
    SF Bay Area
    Ken
    Which sniffer do you have? I don't think mine works very well.
  2. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    906
    S La
    Robinair TIFL1-A. Relatively inexpensive and not as sensitive as the more expensive units but it worked just fine for me. You must be in dead calm air and get the wand tip close to find the very small leaks.
  3. INRange
    INRange F1 World Champ
    12,469
    Virginia/Florida/Caymans
    JD
    The oval pipe is a result of the condenser fitting becoming distorted in the welding process. Once the fitting took on the oval shape...the pipe was forced....tightened down and took on that shape. The O ring should have sealed fine.
    I respect your choice not to flush the system but I don't know why you wouldn't do it......especially if you are replacing the compressor with a new one. The oil looks more than two years old. I just wonder if the rebuilt compressor you have is just more of a used part than one that was disassembled and rebuilt. A lot of shops can't tell the difference. We used to refer to suspect "rebuilt" parts as "Gunk" rebuilt.....meaning that the only thing that was done was the part was sprayed with a can of Gunk.
    My money is still on the compressor. One way to prove it is to cap off the compressor lines and vacuum the system. $20 says it holds a vacuum.
    TheRealFlyingBear likes this.
  4. Skidkid
    Skidkid F1 Veteran
    9,505
    Campbell, CA
    John Zornes
    Polar Bear is pretty well known; I think they do a decent rebuild. I do recall seeing one thread complaining about a bad part but that happens in every business.
  5. INRange
    12,469
    JD
    I was referring to the one installed in the car (made in Korea) which to my understanding was rebuilt. Polar Bear does a good job on compressors.
    TheRealFlyingBear and Skidkid like this.
  6. TheRealFlyingBear
    Apr 27, 2020
    152
    SF Bay Area
    Ken
    @INRange
    Capping the compressor lines seems like a good test. I'll need to source some caps in the appropriate size. I'd like to do this test when the compressor is being rebuilt by Polar Bear. I agree, I suspect the leak is the compressor. Only having 1.5oz of oil in it may have also made the seals dry and more likely to leak. The shop that installed this compressor says the normal oil color is orange (strange choice IMO considering orange/brown is the color of bad fluid). However, the fluid does look pretty clean and clear.
    For now the car is fully assembled and my plan was to drive it around a bit before doing a full overhaul on the AC system (new condenser and compressor rebuild). It's been two months without enjoying the car due to the rock chips repairs and clear film install. My film install was supposed to be Sept 5th, but it might get pushed out because there's so much ash in the California air that my installer thinks we should wait until the fires have calmed down. If the film install gets pushed out a couple weeks, I may end up doing the AC overhaul, now. Silly considering it always takes me about an hour to reinstall that darn rear under tray and I just put the front bumper back on...I love to work on my car? :p
  7. INRange
    12,469
    JD
    Enjoy your car now. Work on it when the weather sucks. You are on the right track to solve it.
  8. TheRealFlyingBear
    Apr 27, 2020
    152
    SF Bay Area
    Ken
    What's the best way to plug the lines going to the compressor? Not sure how this is normally done, but I was thinking about buying some hardware at home depot that's the right thread size?
  9. INRange
    12,469
    JD
    That works. Anything to cap the lines and you are good to go. Plug into the low or high side port and pull a vacuum. 15 minutes and you will have your answer.:)
  10. Skidkid
    Skidkid F1 Veteran
    9,505
    Campbell, CA
    John Zornes
    As I recall, it is 1/4" flare fitting
  11. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    +1
    The first hint of actual science in this whole thread.
    You tune the A/C system using SubCooling.
    First measure the Superheat off the evaporator and then start filling until the condensor subcooling matches.
    My Testo 550 performs these with sensor probes and the whole task is so easy to optimize an A/C fill.
    BTW, Ever wonder how OEM determine how many pounds to actually fill the system?
    They do just this above, they fill until they balance the SuperHeat with SubCooling to result in the fill weight.
    A balanced system provides optimum cooling capability
    TheRealFlyingBear and flash32 like this.
  12. TheRealFlyingBear
    Apr 27, 2020
    152
    SF Bay Area
    Ken
    Finally finished with paint repairs and had clear PPF installed on the car. Things were delayed due to paint issues and bad air quality, but my 360 is finally finished! Driving around the past week it actually seems like my air conditioning is fixed. It's too cold inside the car even when it's 100F outside!
    To summarize what was done:
    1. replace most o-ring seals (excluding evaporator)
    2. new dryer filter
    3. replaced control valve inside the AC compressor
    4. drained old AC oil from the compressor, refilled with fresh fluid
    5. empty & refill system with refrigerant
    Superheating and subcooling sound interesting to learn more about. It looks like I already had measured all the datapoints to calculate both values (spreadsheets linked earlier in the thread). If anyone is interested in doing this calculation for their own car, you can find the formulas and steps here. For now I'm going to move on to other sounds on the car.
    https://www.hunker.com/13407349/refrigerant-overcharge-problems
    Thanks to everyone on this thread for their help, information, and support. @flash32 @INRange and others who helped... THANK YOU! =)
    flash32 and INRange like this.
  13. INRange
    12,469
    JD
    Great work....congrats!!! Enjoy your car!
  14. Ruz1
    Ruz1 Rookie
    27
    So Cal
    David
    Congrats on finding a fix and what a generous amount of information from the group, after reading this I found myself wanting to learn about a/c, be careful what you wish for, I went for a Saturday morning drive to visit to visit mom and turned on my ac for the first time since I acquired the car a month ago, and low and behold no cold air, turned on the ac on high and I don't hear the compressor "cycling" aka turning on, and I checked the fuse next to the battery and its good then checked the fuse behind the driver and that's good, any suggestions on what else to check to see if the compressor is good? or what should my next step be?
  15. TheRealFlyingBear
    Apr 27, 2020
    152
    SF Bay Area
    Ken
    Ruz, I found the experience really interesting and satisfying. I also saved $$ and now have a complete set of AC tools I can use in the future. However, I'd only suggest DIY'ing this if you're okay not driving your car for a while. I left my car up on quickjacks for about a month while I was waiting for paint to dry. This allowed me plenty of time to experiment with AC and learn about the system and tools.
    If you have the time to leave your car in-operable...time to get underneath and see if the compressor clutch is working. If it is, I would get a set of manifold gauges and use them to start diagnostics.
    synchro likes this.
  16. Ruz1
    Ruz1 Rookie
    27
    So Cal
    David
    Thank you for the encouragement, I'm going to start looking for a good set of manifold gauges. nad then ill put the car up on Quickjacks.
  17. Ruz1
    Ruz1 Rookie
    27
    So Cal
    David
    Any Suggestions on which manifold gauges to get?
  18. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,852
    Central NJ
    Dominick
    My research always pointed to yellow jacket
    Sent from my moto g(7) using Tapatalk
  19. Ruz1
    Ruz1 Rookie
    27
    So Cal
    David
    Thank you, I will use that as a starting point.
  20. TheRealFlyingBear
    Apr 27, 2020
    152
    SF Bay Area
    Ken
    Yellow jacket would be solid. If you're budget is lower, I got the AC Pro gauges from Amazon. They're also sold at autozone and orilley so I assumed they would be "okay".
  21. kaj750
    kaj750 Formula Junior
    May 9, 2022
    271
    Fresno, CA
  22. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,852
    Central NJ
    Dominick
    Try Evac and refill ..
  23. kaj750
    May 9, 2022
    271
    Fresno, CA
    I'll give it a shot tomorrow. Wish me luck! You know I could use some LOL
