News
360 alarm battery change.
Discussion in 'Technical Q&A' started by paulsmig, Nov 26, 2009.
  1. paulsmig
    paulsmig Rookie
    Nov 26, 2009
    2
    Hello
    I've recently bought a 2003, 360 F1, which i love.
    I've been looking throught the threads, and iv read that if the alarm led (Right of the steering wheel) stays on when the engine is running the batteries are dead.
    Is this correct. Should it flash when driving ?.
    My light is constantly on when the engine running.
    Can any one tell me where that batteries are located, and if any knows where i could buy some from. Pls be precise with the location.
    Paul
  3. flipdowt
    flipdowt Karting
    Dec 13, 2008
    204
    Mahopac,New York
    John Flip
    if you go to the search tab and type in "360 alarm battery" you will get more info than you can imagine, i'm sure it will help
  4. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,446
    Dublin, Ireland
    Greg
    As he says ....... use search
    but to answer your question, if the light stays on or flashes continuously when engine running then you have an alarm fault which most likely means you've got that same problem - dead battery in the siren (which is located behind the bulkhead at the back of the front luggage compartment........
    Happy hunting.
