Hello, My 360 blower stopped working no heat, ac or anything. I remember a few years back reading about the resistor that goes bad and requires the dash being pulled. Anyone have links or info as to the part that needs to be replaced etc? Thanks Jr
Dash doesn't need pulling if it's the resistor. It's on the r/h side of the heater box, under the dash. Get someone to diagnose it for you before throwing parts at it needlessly.
Awesome, thanks for the info. Do you happen to know a part number were to get the resistor. All fuses and blower have been checked and function.
Item number 11 on this page; http://www.eurospares.co.uk/partTable.asp?M=1&Mo=688&A=2&B=40735&S= Before you replace the resistor try disconnecting and reconnecting the ecu. These are known to suffer with resistance issues in the plugs.
Yes, it's a transistorised block with big aluminium cooling fins on it, which is a sealed unit. If you take it into a Diavia dealer they may be able to cross-reference it and get it cheaper though.
