Hi, Has anyone done the conversion of fitting front and rear 360 calipers on a 308 gt4? Including handbrake calipers? And under 16" wheels. Any help pictures or diagrams would be much appreciated.
Did you use rear handbrake calipers? What size disc/wheel combination did you use and was there a big improvement in the brakes?
I did. Both front and rear. No emergencybrake callipers as I used an inline hydraulic brake I use 17” but during testing I used trx wheels I did not use 360 disks or 308 disk but a split type disk from superformance. Callipers with costum build brackets
Thanks. Something along these lines are what I’m looking to do. Have you got any dimensions for the brakes?
No. I started with an MDF( wood) for modeling and defined dimensions. After that I had them water-cutted from duralumin. But do not have the drawing anymore
No only the callipers. I did use a new , slightly larger main cilinder. Bought new from a fiat Ducato van. Same outside but slightly larger bore I did ad an adjustable valve to enable balancing between front and rear
