360 break discs fitt 355?? | FerrariChat
Discussion in '348/355' started by chaa, Mar 2, 2004.
  1. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    I have put this on Tec but have no answers. So i will ask here. Can them bigger drilled discs fit from a 360 to 355.Haveing bracket made for the calipers is not a problem, i have done similar on other cars in the past, i just need to know about the discs. Please.
  3. cpdred
    cpdred Rookie
    Mar 1, 2004
    10
    uk
    craig
    i dont think they will if you want better brakes why not fit 355 challenge discs and calipers though you may have to fit the wheels as well
  4. sherpa23
    sherpa23 F1 Veteran
    9,890
    Rocky Mountains
    Bastuna
    I have the upgraded Brembo brake package (F50 brakes on the front and F40 brakes on the rear) on my 355. As you would suspect, they work incredibly well.
  5. F40
    F40 F1 Rookie
    Apr 16, 2003
    3,227
    I've been in a 348TS with F40LM front brakes and F50 rears... The 348 & 355 are similiar... So I'm sure the same set up would work... Under braking I nearly hit my head on the windsheild.
  6. sherpa23
    sherpa23 F1 Veteran
    9,890
    Rocky Mountains
    Bastuna
    Patrick, are you sure that it wasn't F50 fronts and F40LM rears? That's the kit.
  8. F40
    F40 F1 Rookie
    Apr 16, 2003
    3,227
    Not sure... Maybe the owner can clear this up... Calling Ingenere.
  9. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,100
    On the Limit
    Dino
    I'm the guy that launched AZGuy's head into the windshield! :)
    The set up I have is F40LMfront brakes and F50 rears. I am about to replace the front hats and am looking into a carbon/ceramic replacement....that should put AZguy through the windshield! It's a good thing that I have 5 point belts!
    Ciao...Dino
  10. sherpa23
    sherpa23 F1 Veteran
    9,890
    Rocky Mountains
    Bastuna
    Dino. that's interesting. I have never seen that set up. Where did you get it?
  11. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,100
    On the Limit
    Dino
    I got the fronts from a team in Europe and the rears from a shop in NJ.
    Ciao
    Dino
