360 Cam Belts Change | Page 3 | FerrariChat
Discussion in '360/430' started by 993turbo, Jan 21, 2014.
  1. captglen
    captglen Formula 3
    1,790
    West Palm Beach, Fl
    Glenn L.
    Thanks Steve
  2. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Lots of time and effort went into your procedure. Very much appreciate your having shared this with the community.
    Fine Job!
    Many Thanks,
    Vincenzo
  3. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,181
    Wash DC area
    Robert
    Added to the DIY section.
  4. Black360
    Black360 Formula Junior
    Oct 11, 2010
    458
    East of Eden
    Appreciate the feedback. I hope to improve the draft with input from those who give it a try.
    BTW: Thanks to F-Chatter "sailingmagnus" for his technical insight and hands-on assistance during the entire ordeal.
  5. tazandjan
    39,359
    Robert- Thanks.
  6. 993turbo
    993turbo Formula Junior
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    Does anyone have more pictures of 3207? I think I can make this for a fraction of the price.
    :D
  7. mr_bock
    mr_bock Formula 3
    Oct 27, 2006
    1,373
    FL full time
    +1
    Should be easy to make... pix please someone
  8. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    I cut up a cheap 944 flywheel holder, rewelded the teeth section to a bar, two holes for mounting, works great.
  9. 993turbo
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    my point exactly.
    i was thinking more in the line of a plate, with two nuts welded to it, and bolts through the nuts. Adjust the bolts to engage the clutch or flywheel.
    Estimated cost: 5$ (really Zero, cause I have the stuff needed)
    Estimated time to fabricate: 30mins.....
    Pleasure of doing it myself and avoiding paying OVERINFLATED Ferrari / Lambo Tax prices : Priceless :D
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Good idea.
  11. Pwcpro785
    Pwcpro785 Karting
    Nov 10, 2011
    71
    New York/Connecticut
    Kevin
    #61 Pwcpro785, Jan 27, 2014
    Made a simple locking plate that bolts in place of the clutch inspection plate (blue tape is holding the socket head bolts for easy keeping)
  12. Black360
    Oct 11, 2010
    458
    East of Eden
    I believe that the Hill Engineering tool is designed to react against the clutch plate, while the tool shown reacts against a tooth (or teeth) on the flywheel. Wondering if Hill was trying to avoid that with their design?
  13. 993turbo
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    I wonder more why they would like to hold the clutch plate rather than the Flywheel? any reason for this?
    Regardless, its easy to make either way, my plan was to make it to engage the clutch as originally intended.
    :D
  14. Black360
    Oct 11, 2010
    458
    East of Eden
    The might not want to stress the teeth on the flywheel. A load path through the flywheel might produce higher stress than a load through the clutch plate, due to stress concentration at the root of the gear teeth.
  15. tazandjan
    39,359
    #65 tazandjan, Jan 28, 2014
  16. 993turbo
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    Or only 550 and 360?
    :D
  17. tazandjan
    39,359
    Remi- Turns out Brian Crall says it will not work on the 550, either. For that you need tool 3546-1.
  18. 993turbo
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
  19. Black360
    Oct 11, 2010
    458
    East of Eden
    #69 Black360, Feb 27, 2014
    I've attached an updated spreadsheet and procedure. (Corrected some errors in the procedure, added pictures, corrected some typos, added more links, etc.)
    If anyone in the U.S., Canada, or Italy plans to perform this task in the near future, and would like someone to lend a hand (and perhaps some tools), let me know.
  20. 993turbo
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    Been busy with my 430 lately, will do the belt job when time permits...
    :D
  21. Mozella
    Mozella Formula Junior
    Mar 24, 2013
    905
    Piemonte, Italia
    Glad to see you mention Aircraft Spruce. For those who don't know, these folks have been selling stuff to the experimental aircraft homebuilder crowd forever. They are a great source for all kinds of hard-to-source material but the big advantage is that they sell in small quantities. Need a few square feet of high tech thermal insulating material or three feet of streamlined high strength steel tubing? Aircraft Spruce is the place to get it.
    I've built a few homebuilt aircraft in my time and it would be hard to imagine doing it without this company to supply components. Check them out if you're a fiddler.
    Pilot Supplies and Aircraft Parts from Aircraft Spruce
  22. vrsurgeon
    vrsurgeon F1 World Champ
    16,619
    Charleston, SC
    Curt
    +1. GREAT source for interesting parts.
    ONe day.. one day.. I'll have that Sonerai I in the barn built. :)
  23. Black360
    Oct 11, 2010
    458
    East of Eden
    Yes, exactly.
    I'm tired of suppliers asking me “How many 50 gallon drums of gear oil do you want to order?”
    BTW: I've also had good luck with Pilots HQ; good prices, small quantities:
    Dow Corning Molykote 55 Oring Grease 5.3oz - DC 55
  24. 2mmuch
    2mmuch Formula Junior
    326
    Ontario
    Luigi
    #74 2mmuch, Mar 20, 2014
    Ok so I decided to do my belts, and i'm in deep. Just finished removing the 36mm bolt from the main pulley. My question is how do you remove the main crank pulley? Do I need a special tool, there is not enough room for my 6" pulley puller. Help.
  25. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    #75 FerrariDublin, Mar 21, 2014
    I haven't done this but........
    Swear at it? :D
    Apply heat and see if you can loosen it that way?
    Tap with a AV-3040-Special-Tool (a Hammer)?
    Get a different puller?
    Wait for someone like Black who's actually done it to come back to you!
    Where there's a will there's a way.
    P.S. Pics and a DIY thread or it didn't happen!!! :D :p :D
