360 cam variator failure | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Clark, Feb 16, 2005.
  1. Clark
    Clark Karting
    Feb 23, 2004
    55
    Suwanee
    Clark Driggers MD
    According to the service the car i was tlaking about had belts and the cam variator campaign done. It then had a tensioner failure and that required the engine replacement. Does that sound correct to you?
  2. Rifledriver
    37,288
    No reason not to believe it if there is documentation.
  3. Modenafan
    Modenafan F1 World Champ
    Dec 19, 2004
    12,069
    Moorpark
    Jon
    Just as a follow up. I took my car in Monday and replaced my timing belts. As a matter of fact I replaced all belts. The belts looked fine, though you never can tell. Variators were also fine. I did end up replacing my left side tensioner. The new tension looks almost twice as thick as my original. My service manager showed me a tensioner that was being replaced on a 2000 360 and it had a slight crack (can't be good). I guess there was a campaign to replace the tensioners on certain chasis numbers. One less thing to worry about. I appreciate everyone's input.
    Jon
  4. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    How do you know the variators were fine? The only way to know is to x ray them for potential small cracks, but really there is no way to know unless you have documentation.
    They will work perfectly until they snap, so no diagnosis will reveal anything.
  5. Modenafan
    Dec 19, 2004
    12,069
    Moorpark
    Jon
    I believe what the mechanic meant was, because there was no campaign on my chasis number and his visual revealed nothing, he told me they were fine. Based on what you're saying, I guess I'm on a hope and a prayer. On the other hand, my chasis number wasn't on the campaign list for the tensioner, yet it was the older smaller type. My guy is checking with Ferrari today to double check on the tensioner. I appreciate the feed back. I will call my mechanic this morning and ask him again about the variators.
  6. 4i2fly
    4i2fly Formula 3
    Apr 16, 2004
    1,333
    SF, Bay Area
    You should also ask for your before and after exhaust cam timing angles reported through SDII, and report them here for any anomolies.
  7. one4torque
    one4torque F1 Veteran
    5,794
    Houston
    One4torque
    Pardon the necro bumpage... researching variator and quick question—/.
    is there a difference in variator failure rates based on trans? Gated vs f1?
    thinking a gated car can’t be shifted like an f1 — does this put less stress on the variator?
  8. Skidkid
    Skidkid F1 Veteran
    9,648
    Campbell, CA
    John Zornes
    Not that I am aware of. The issue is how the neck of the variator is designed. The forces are caused by high RPM. The redesigned the variator not once, but at least 3 versions. I don't see how F1 vs manual will change any of that but I am open to hear differently from the experts.
  9. one4torque
    5,794
    Houston
    One4torque
    Skid- I was thinking of fast clutch engagement at redline repeatedly.
    My reading shows this is a fatigue failure.
    now a money shift w a gated car will do bad things as well
    Would be interesting to pull data on stick cars vs f1. Might tell something.
  10. Skidkid
    Skidkid F1 Veteran
    9,648
    Campbell, CA
    John Zornes
    I still don't buy it. The mass of the valve train isn't that much and definitely not enough to exceed the elastic limits of 1" thick steel. The changes in design aren't about fatigue. They changed from a sharp angle to a shallow curve effectively distributing any force in that focused area and reducing tendency to crack at the sharp point/angle.
  11. one4torque
    5,794
    Houston
    One4torque
    It would be interesting to compare the driving habits of f1 drivers vs gated.... f1 allows you to bang off every gear up and down w a paddle. Vs gated is slow and clunky... perhaps there a difference in loading between the two.
    I’d just be curious to see the data.
    it prob only exists at the mothership
    BigTex likes this.
  12. BigTex
    79,408
    Houston, Texas
    Bubba
    I think the first variator design cut two deeply into the metal stock and the crack failure propagated from there..
    There was a car in OZ that failed AFTER the variator campaign, trashing the motor, so I guess I was not aware of Design Version 3, but not surprised.
    Interesting on the tensioner support recall but either one and you've had damage.
  13. BigTex
    79,408
    Houston, Texas
    Bubba
    6 speed guys are "in no hurry" we just "out cruisin'.."
    :D :D :D
    Oh wait, I only have 5 gears...lol
    one4torque likes this.
  14. tbakowsky
    Sep 18, 2002
    20,063
    The Cold North
    Tom
    I have been fixing these things since they were basicly new. I have seen 2 variator failures.. 2. I have seen more engine failures due to abuse then a failure of a variator. That said.. all should have been repaired by now.
  15. RedNeck
    RedNeck F1 World Champ
    12,560
    The CSA
    Me
    Nope. Mine's getting done during my next major...which i overdue.
  16. tbakowsky
    Sep 18, 2002
    20,063
    The Cold North
    Tom
    Are you the original owner?
  17. RedNeck
    12,560
    The CSA
    Me
    Nope, got it in 2016. I just have no green dots, no VD, no records on modis, and am knocking on 60k, so I already have the parts (major plus both tensioner and variators), just need to get it scheduled. Normally a DIY guy, but not attempting this one on my own.
  18. tbakowsky
    Sep 18, 2002
    20,063
    The Cold North
    Tom
    So you don't know if they were done or not..yes?
  19. RedNeck
    12,560
    The CSA
    Me
    Correct....but I have no reason to believe that they were.
  20. Skidkid
    Skidkid F1 Veteran
    9,648
    Campbell, CA
    John Zornes
    They didn't all break. It was just a weak point that was expensive if it broke under warranty.
