So a couple of questions: 1) Did you use the flywheel locking tool to keep the crank (which i guess is conected internally to the lower cam belt drive pulleys you say you marked up for the timing? 2) Did you need a puller to get the main pulley off? 3) So did you replace the tensioners and the tensioner bearings? (these are separate, right?) Thanks
