360 Challenge/Stradale Manual build thread | Page 12 | FerrariChat
Discussion in '360/430' started by Julian Thompson, Jul 26, 2016.
  1. Julian Thompson
    Julian Thompson Formula Junior
    769
    Cheshire UK
    Julian Thompson
    #276 Julian Thompson, Oct 27, 2016
  2. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #277 Julian Thompson, Oct 27, 2016
  3. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #278 Julian Thompson, Oct 27, 2016
    And this is why I'm doing it - some bearings seized, some sloppy. All those little points add up to a less than perfect manual shift. This little rebuild is well worth it to refresh a manual car.
    Note that when you press the little ball joints out they are staked (hard to see) in three places on each joint. I just pressed them out and the stakes failed easily under the weight of the press. I then cleaned them off with the Dremel and will restake that side once the new bearings are in.
  4. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #279 Julian Thompson, Oct 27, 2016
  5. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    Just out of curiosity why did you choose to get rid of the sensors from the F1 to manual?
    My thinking was it would be easier to swap to F1 in the future if you so desired if you'd left them in or is there a technical reason which precludes doing this?
    -T
  6. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #281 Julian Thompson, Oct 28, 2016
    Morning Sir - no technical reason but my car is a factory manual and the Stradale box was delivered to me with just this hole! So I needed to do something with it :)
  7. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #282 Julian Thompson, Oct 28, 2016
    Finished pressing in all the bearings and then selector levers cleaned up, finished and reassembled for trial. there is no slop at all now in the mechanism.
  8. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #283 Julian Thompson, Oct 28, 2016
  9. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    Nice work! Definitely the best way to get the most from that glorious shift action.
  10. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #285 Julian Thompson, Oct 29, 2016
    Turning my attention to the engines today I worked to remove the inlet manifold and left and right dme looms off the 28k Modena engine.
  11. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #286 Julian Thompson, Oct 29, 2016
  12. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #287 Julian Thompson, Oct 29, 2016
    Really the only interesting thing was that the right hand dme loom was actually connected to the left hand throttle, and vice versa.
    I would love to know if this is intentional or a mistake?
    Anyone know?
  13. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    The way the inlet manifold works is to cross the airflow from the LHS air intake over to the RHS of the engine (and vice versa). At higher revs the the manifold changes length and the LHS air goes into the LHS of the engine.
  14. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    Perfect - thanks Aldous !
  15. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #290 Julian Thompson, Oct 30, 2016
    With the intake in bits I noticed some oil vapour residue in the chamber here. This is caused I presume by oil vapour not being purged of the liquid oil after being blown past the rings. In race cars it's a common practice to use an off board catch tank to solve this issue and prevent the oil sludge from being inducted back into the motor. The intake gaskets also have evidence of damage from the contaminated mixture.
    I had a look at the challenge car - same setup I notice - though there does appear to be a revised disareator on later cars? Also took a look at the NGT car to see how they worked the breather setups on that but the pics were pretty poor.
    Ideas?
  16. FlyingHaggisRacing
    FlyingHaggisRacing Formula 3
    Jul 2, 2013
    1,377
    Steam clean that bugger :)
    I've now had the pleasure :( of looking inside 2 x360 engines and find a number of common items (more later). One of which is, there always seems to be a film/layer/small pool of oil sitting in the bowl of the intake boxes.
    I doubt you'll find any form of PVC /sucking oil vapour into the inlet on a race engine. (given that Challenge cars at that time were more like road cars).
    For me - having had the fun of removing the tar from the inlet/exhaust ports and valves = no more sucking oil vapour in to the inlet manifold.
  17. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    I'm with you on it. So we need a catch tank setup - what about crankcase pressure how's that gonna work?
  18. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    Given it's a road car what about a better separator in line with the feed to the plenum, or wherever the inlet connection is? You can have the drain from that going to the disreator.
  19. stevecomp
    stevecomp Formula Junior
    Mar 1, 2013
    743
    South Australia
    Steve
    The two breather pipes that go from the oil tank to the throttle bodies can be reduced in diameter, put a jet or a bit of round bar with a 1mm hole this will reduce the oil mist but not make any back pressure issues rather than just blanking off or catch tank.
  20. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #295 Julian Thompson, Oct 31, 2016
    Looked at it - probably best to retain the suction from the manifolds and just insert the tank in line from the disaerator to the inlet. Although that still allows the first condensed Gunky oil to feed back into the main oil supply.
    I might have a very brief look at the disareator to see if it could be redesigned to incorporate a tank.
    But in the mean time this one looks sensible and appropriate for the engine bay: (don't want a "hks greddy twin turbo anodised blue" one with a "killer power" sticker heheheh
  21. stevecomp
    Mar 1, 2013
    743
    South Australia
    Steve
    The 1mm hole is what's used on a lot of 360 race motors.
  22. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    Hmmm yes - I'm just reticent to pipe anything back into the inlet to be honest steve if it can be avoided. I've always designed my race cars on open loop like this so seeing the Ferrari all messed up like this kind of convinces me?
  23. FlyingHaggisRacing
    Jul 2, 2013
    1,377
    "Wow, you guys have been busy whilst I was out putting the cams in on the new head and picking up the air box (powered coated it at the weekend).
    .... still hoping not to fit it, waiting for Steve's alternative :)
    You don't want..."hks greddy twin turbo anodised blue" !
    - bugger that was my favourite - page 54 of the 'Demon Thieves' catalogue.
    So mine is '99, and the oil tank has 3 outlets...2 big and 1 small.
    a) the small one goes via a T to two 90deg small outlets on the air boxes.
    b) one big one is T to the outlets of the throttle bodies.
    c) one big one goes to outlet of the cam covers which is T together.
    so....
    c = is venting into the oil tank = we need this one.
    so a + b are sucking oil vapour, which is not allowed to vent to air thanks to clean air act (which we might overlook).
    So what hidden purpose is there to the feed going to the throttle bodies ?
    Is there a reason or is it just that F.Challenge rules require everything to stay spec. and inserting a restrictor (1mm) cuts down the problem but complies with the rules ?
  24. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    My understanding of "positive crankcase venting" is that we are using the inlet suction to ensure the vapour and blow by products are evacuated smartly from the crankcase.
    That's why we need to hook to the inlet and that's why in the turbo applications there is a valve stopping the inlet pressurising the crankcase under boost!
  25. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    I.e we are not aiming to return he sludge to the inlet and neither were Ferrari. They were aiming for the disareator to remove all that and use the suction only as a function.
    Unfortunately the disareator doesn't seem to work exactly perfectly - although it's a decent effort if you look up the back of it - plenty of baffling and complexity to persuade the oil to de mix from the vapour.
    1) one option would be to fit a single catch tank between the cam covers and the disareator.
    2) another option is a single tank from the disareator to the plenum.
    3) third option is both 1 and 2
    4) And a fourth option is to connect the cam covers to a catch tank, then directly to the inlets, thus abandoning the disareator function and relying solely on the tank.
    I'm thinking carefully...
