360 Challenge/Stradale Manual build thread | Page 17 | FerrariChat
Discussion in '360/430' started by Julian Thompson, Jul 26, 2016.
  1. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    Great guide for people who haven't done this. Getting the right puller really saves a lot of headache as you allude to!
  2. stevecomp
    stevecomp Formula Junior
    Mar 1, 2013
    743
    South Australia
    Steve
    Good job mate 👍 the alternator is one of the major parts that are subject to failure on a 360ch. They get stupid hot and very little air, I always have a spare one when racing.
  3. Julian Thompson
    Julian Thompson Formula Junior Silver Subscribed
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
    So here is the rebuild of the alternator with some pictures and hopefully helpful points.
    First off the case was cleaned with petrol and the bearing fit and stator fit surfaces were masked. The unit was then refinished.
  4. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
  5. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
    The new bearing is installed by warming the holder in the oven a little, sticking the bearing in the freezer and then just dropping it in. Tap the bearing until the front face is flush. Don't tap the inner race, obviously.
    Then fit the interference fit pins (note different length) back into the case with a smart tap.
  6. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
    I cleaned up the slip ring and refinished the slightly flaky paint on the rotor using some red paint. It's a bit glossier than the factory red.
  7. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
    Now you can push the slip ring through the bearing. Don't forget the thin washer. Tap the case over the shaft until the washer bottoms out. Obviously don't hit the slip ring!
  8. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
    Now the stator and the rear case bearing can be fitted. Again use the oven to warm the case through to about 140 and freeze the bearing.
    Work smartly - remove the unit from the oven, tap the bearing in and then without letting the case go cold fit the stator.
    You need to make sure the stator lines up with the rear case so do a trial fit first and mark the case, and when you insert the stator make sure it goes in straight. Mine went in a bit crooked, got stuck and then as it all cooled I had to use a punch to tap it down so it was fully home. If it had gone in level it would have just plopped in I'm sure.
  9. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
  10. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
    Now the four main bolts can be screwed in to retain the stator and the case halves can be brought together and tapped down onto the shaft.. Once these are close you can fit the 4 nuts and drag the whole thing together.
  11. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
  12. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
    Rectifier can get fitted, first making sure the stator connections are bent nicely to line up as replacement rectifiers can be slightly different sometimes.
  13. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
  14. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
  15. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
  16. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
    Couldn't resist bolting it onto the Stradale engine - pleased - looks new and the whole job cost about $100 in bits which is about the cheapest thing I've ever done to the car!
  17. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
  18. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    Great work. One of those satisfying jobs!
  19. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
    Yes Mark I just have to keep focussed on the bit I'm working on. I don't know about you but if you step back and look at the whole project it gets a bit overwhelming when you have one single assembly stripped in to about 200 pieces.
    The alternator job took ages because I had to get the replacement bits and the guy was really slow. The intake manifold reassembly is next and that will relieve me of hundreds of refurbished components sat on a tray. I think I'll feel better at that point as I can get cracking on rebuilding the driveshafts and then move to the engine for those seals and things that were mentioned earlier.
    As an aside I recently bought a big Dewalt impact gun as I was struggling to remove the rear hub nuts using - well - anything. I cannot tell you how impressed I am with this thing. Literally it removed the hub nuts in about thirty seconds and I didn't even bother trying to dremel or heat the stakings in the nuts. Unbelievable and one of those tools that I'm now wondering how I've done without!
  20. Chrisnlbc
    Chrisnlbc Formula Junior
    Jan 9, 2015
    374
    Huntington Beach
    Just read your whole thread. Awesome work and thanks for taking the time to share with us on your Journey!!
  21. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
    That's very kind thank you. I'm trying to keep the diary up yes because although I know it's very detailled I always enjoy reading everyone else's rebuild threads so I felt it to be a duty to spend the time myself even though my car isn't a madly exotic classic like a Dino or a 512.
    I'm certainly enjoying doing it but getting a bit jealous of the "here is my car in the sunshine threads" heheh
  22. Drestless
    Drestless Formula 3
    Oct 1, 2014
    1,251
    Riverside, CA
    Jam
    Looking good. I will slowly do all this refurbishing on my 360 myself as time goes by.
    This thread got me motivated.
  23. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    Haha yes it becomes a bit too much like work/the day job if there's too much going on. I like to try to limit that and keep enjoying it by focusing on a few things at a time.
    I have a compressor in my workshop with a range of attachments but that pre-dates the newer battery powered stuff which really is awesome. I could do with a battery impact gun for the convenience aspect.
    Love DeWalt tools!
  24. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    What a thread! Insane detail. I didn't notice anyone mention the GT3 in some of the pics :)
    Anyway thanks for all the details and I look forward to your future updates.
  25. Julian Thompson
    Apr 25, 2016
    769
    Cheshire UK
    Julian Thompson
    Well it's been a bit of a while but I've been doing a few bits to the car in the background whilst my work has been really hectic.
    First off I refurbished the drive shafts. They were badly corroded on the outboard end.
    Nasty
