360 Challenge/Stradale Manual build thread | Page 18 | FerrariChat
Discussion in '360/430' started by Julian Thompson, Jul 26, 2016.
  1. Julian Thompson
    Julian Thompson Formula Junior
    769
    Cheshire UK
    Julian Thompson
    #426 Julian Thompson, Feb 18, 2017
  2. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #427 Julian Thompson, Feb 18, 2017
  3. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #428 Julian Thompson, Feb 18, 2017
  4. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #429 Julian Thompson, Feb 18, 2017
    Finally they were reassembled with new gaiters, clips and covers. Originally the outboard ends are zinc plated but looking at how badly that did I think the black coating will be a good plan. One point is that the clamps supplied by Ferrari in the gaiter kit for the small end are too small and had to be replaced.
  5. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #430 Julian Thompson, Feb 18, 2017
  6. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #431 Julian Thompson, Feb 18, 2017
  7. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #432 Julian Thompson, Feb 18, 2017
  8. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #433 Julian Thompson, Feb 18, 2017
    The flat screws were used to bolt the butterflies back in. I used extreme care and loctite 270 in copious quantities. Really don't fancy a screw falling out...
  9. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #434 Julian Thompson, Feb 18, 2017
  10. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #435 Julian Thompson, Feb 18, 2017
  11. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #436 Julian Thompson, Feb 18, 2017
  12. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #437 Julian Thompson, Feb 18, 2017
  13. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #438 Julian Thompson, Feb 18, 2017
  14. sierra055
    sierra055 Formula Junior
    362
    Melbourne, AU
    Marshall
    Looking great Julian, good to see some updates again!
  15. jochem00
    jochem00 Formula Junior
    Jun 19, 2014
    344
    Netherlands
    what do you use to clean the cast aluminium parts? Just petrol?
  16. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    Hi guys. Thanks. It's been very slow but I'm gaining momentum again - It helped to move the GT3 into storage and now the F car is in the garage so that makes it easier.
    Petrol is my go to degreaser for most things, yes. But on a big casting like the inlet manifold where it is literally bare of any other parts I use a simple water based one as well.
    There is a guy on here in another section (think it's BB) who has discovered a way to get aluminium looking bright and totally clean just by treating it with something. But when he was asked he refused to tell, explaining that it has taken him a long time to work it out. (He's not a hobbyist this guy it's a commercial enterprise for him so you can understand it) -- anyway -- it can't be too difficult to work out if you know things about materials in a chemical way (my knowledge is very rudimentary) and if you do please let me know!
  17. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    Try Lemon juice or White Vinegar mixed with water.
  18. euro_king
    euro_king Formula Junior
    Mar 18, 2009
    759
    San Jose, Jakarta
    Jastien Weiss
    this project is so awesome, keep us posted
  19. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #444 Julian Thompson, Mar 15, 2017
    So at the moment I'm working on mechanical things on the engine - getting ready to time the cams, replace cam seals and rear main seal. Fair bit of refinishing going on like these cam covers which look a bit fresher now.
  20. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #445 Julian Thompson, Mar 15, 2017
    Something that might be of help to someone else. I noticed that my fuel gauge would read reasonably linear down to around 4/5 empty but then the gauge would "stick" and eventually the car would run out of juice with the indicator still reporting fuel present.
    I've read a few things about bending the fuel arm etc but I was not wholly convinced so I cracked the whole thing open to take a look.
    Here you can see the whole assembly with the fuel arm sat flat on the "bench" lol.
    Also my lovely Mrs sat having a beer!
  21. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #446 Julian Thompson, Mar 15, 2017
    Specifically, in my case, the issue was a dead spot in the wiper type resistor that is attached to the float arm.
    This is a "post cleaning" photograph with the issue solved. I just used some fine wet and dry sandpaper to clean the resistor board carefully and measuring it with my meter the dead spot disappeared instantly and the arm moving now results in a resistance of around 3 ohms "full" to around 300 ohms "empty"
    Obviously I'm some way off (ahem) actually being able to report that it's solved the issue on the road but in principle I think it's done.
    Hope this helps at some point :)
  22. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    #447 Julian Thompson, Mar 15, 2017
    Since most of the posts for my project have not really hinted at what is in store and it's taking so damned long I thought I'd include a pic of a set of little brakes I found knocking around in my project storeroom, just to liven things up a bit!
  23. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,775
    Ahh, nice. You bought one if the Eurospares kits, then?
  24. Julian Thompson
    769
    Cheshire UK
    Julian Thompson
    Yes Mark I did - they were just too good value to resist and like I said to Emma great value for £100 😬
  25. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    Tell Emma if they are 100 quid I'll buy 100 sets!!! :)
