News
360 Check Engine Light
Discussion in 'Technical Q&A' started by jerryf, Oct 19, 2020.
Tags:
  1. jerryf
    jerryf Rookie
    Aug 1, 2007
    4
    Altoona, PA
    My 360 has Fabspeed headers, Hyperflow Cats and Fabspeed exhaust. It has a constant check engine light, I am told by the previous owner it is due to the Hyperflow Cats running cooler than the restrictive factory Cats. This sounds reasonable since an apparent comparison is made between entry and exit Cat temperatures. Surely many others have had this problem. Fabspeed sells a tiny Cat with the sensor and the end of it, apparently to address this issue. Any ideas? Has anyone used the Fabspeed gadget? Other suggestions? Thanks...
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    10,521
    San Carlos, CA
    Mitchell Le
    You can try many things .... in the end what works is to re-flash the ECU to fake out the cat monitor.
  4. jerryf
    jerryf Rookie
    Aug 1, 2007
    4
    Altoona, PA
    Sounds like a plan. Thanks.
  5. vincep99
    vincep99 Formula 3
    Silver Subscribed Owner
    Jun 8, 2009
    1,809
    I myself would first read out the code to see what the check -engine light is referring to,.
  6. yelcab
    Nov 29, 2001
    10,521
    San Carlos, CA
    Mitchell Le
    There are about six codes that would be thrown in this scenario: Cat efficiency, slow O2 signals for each cat and each O2 sensors. A very well known issue among the non-OEM header users.
  8. Bob in Texas
    Bob in Texas Formula 3
    2,351
    Just East of Weird
    Bob
    Do as suggested above or you might call Fabspeed directly.
    Ff you do a search you'll find several threads on this issue with varying degrees of success using the mini cats. If I recall another brand of mini cats has proven successful. Bigdaddysgarage. But before you go buying them review the earlier threads.
