360 Cold Start Stumble and Rough Idle | Page 5 | FerrariChat
Discussion in '360/430' started by dsevo, Jun 13, 2007.
  1. spyros tsiamantas
    Dec 9, 2019
    11
    Cyprus
    spyros tsiamantas
    Okay sir thank you very much
    I will try and I will let you know
    Regards
  2. spyros tsiamantas
    Dec 9, 2019
    11
    Cyprus
    spyros tsiamantas
    Thank you very much
  3. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
    Thanks for sharing that. I will surely try it. I’ve seen a lot of threads on this issue.
    I’m sure there may be many reasons for the cold start issue but this is an easy remedy for a specific cause that changing parts won’t fix.
    -ray
    spyros tsiamantas likes this.
  4. vwpartsman
    vwpartsman Karting
    Aug 19, 2013
    89
    Washington
    My car was doing a really rough start, even after sitting for 4-5 hours......I’ve read all the threads and this spring when doing maintenance, I cleaned the MAF’s, put a new battery in, which it needed and cleaned the throttle bodies.......when I was tightening the throttle body, the rubber boot starting turning where it meets the intake. The left side did but the right side not as much. I could grab the throttle body and turn it easily with my hand with the air cleaner clamp unhooked. The stock clamp from the boot to the intake is a clamp type, not screw type clamp. It’s was way too lose right there. So I pinched the clamps tighter on the intake side and all the clamp type clamps that I could find, big or small. It’s never cold started better. Yes I changed/cleaned a lot but I think it was the loose clamp that caused it all. I’ll probably pull all the pinch type clamps and replace them with screw type ones one day.
    I hope this helps on some cars.
  5. spyros tsiamantas
    Dec 9, 2019
    11
    Cyprus
    spyros tsiamantas
    Thank you very much for your answer and your help. I will check and I will let you know
    Thank you very much again
  6. freccia75
    freccia75 Rookie
    Feb 9, 2017
    15
    Switzerland
  7. Qavion
    Qavion F1 World Champ
    14,018
    Ian Riddell
    It's probably not a good idea to clean MAFs with anything other than MAF cleaner, but in this case, it seemed to work.
    spyros tsiamantas and freccia75 like this.
  8. spyros tsiamantas
    Dec 9, 2019
    11
    Cyprus
    spyros tsiamantas
    Much appreciate
    freccia75 likes this.
  9. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,105
    Calif
    Brett
    I wouldn't do that. I have never needed to as I have it on a tender. Cheers!
  10. hessank
    hessank Formula 3
    1,898
    Canada, Florida
    Fred
    I was told by the 80 year old gentleman that sold me the car to wait for the OK then the beep to stop ( about 10 secs later) then turn the key fully.
    Worked every time for me
