News
360 conversion
Discussion in '360/430' started by RANDY6005, May 19, 2018.
  1. Need4Spd
    Need4Spd F1 Veteran
    6,096
    Silicon Valley
    Yeah? Try the spider intake! More holes than tube!
  3. RANDY6005
    RANDY6005 Formula 3
    1,785
    Jacksonville
    RANDY
    #702 RANDY6005, Aug 17, 2020
    Stock shock bolts full length threads no grip length shocks rest on the threads. I found theses Ti bolts that has 10 mm grip fits perfect and there weight half .
  4. RANDY6005
    RANDY6005 Formula 3
    1,785
    Jacksonville
    RANDY
  5. RANDY6005
    RANDY6005 Formula 3
    1,785
    Jacksonville
    RANDY
  6. To remove this ad click here.
  7. 24000rpm
    24000rpm F1 Rookie
  8. RANDY6005
    RANDY6005 Formula 3
    1,785
    Jacksonville
    RANDY
    Yes 24000rpm you are right, the wheel well fasteners should be 6mm they sent me 5mm , did not notice until I tried to install them last night.
  9. brogenville
    brogenville Formula Junior
    954
    Robin
    Randy - I think you may need mental help.
    (In a good way! ;))
    RANDY6005 likes this.
  10. To remove this ad click here.
  11. 24000rpm
    24000rpm F1 Rookie
    I thought oem should be 6mm. not sure about that
    also it seems (im not sure either) , that there should be a smaller washer on my CS's wheel well screws. In your pics, I don't see any.
    so basically there should be 2 washers for 1 screw?
  12. RANDY6005
    RANDY6005 Formula 3
    1,785
    Jacksonville
    RANDY
    New CS Lexan glass , should have the rear CS hood done in a few days just about done with the rear suspension waiting on more Ti fasteners . Notice the finish on the wheel well used 3m Professional grade rubberized undercoating may help damped sound of gravel hitting the wheel wells .
  13. RANDY6005
    RANDY6005 Formula 3
    1,785
    Jacksonville
    RANDY
    mwstewart likes this.
  14. 02360spider
    02360spider Formula 3
    1,220
    Sell me that old rear lexan glass.
    Sent from my SM-N975U using Tapatalk
  15. RANDY6005
    RANDY6005 Formula 3
    1,785
    Jacksonville
    RANDY
  16. RANDY6005
    RANDY6005 Formula 3
    1,785
    Jacksonville
    RANDY
  17. RANDY6005
    RANDY6005 Formula 3
    1,785
    Jacksonville
    RANDY
    Started the front suspension , I can pull the rear suspension apart and back together again around 30 minutes now.
  18. MCASEY
    MCASEY Rookie
    Apr 1, 2015
    42
    Sydney Australia
    Sir, I would like to replicate the heat shields in your picture. Would be so kind and take some measurements for me. I suggest that you lay some paper over the panel, then draw lines along the sides, holes and ridges. Don't worry about the round section for the fluid tank. TIA. M
  19. RANDY6005
    RANDY6005 Formula 3
    1,785
    Jacksonville
    RANDY
    #720 RANDY6005, Aug 22, 2020
    There at paint shop now wend I get them back I see what I can do . I have a person here in town that may cam fab you a set if you like .
  20. RANDY6005
    RANDY6005 Formula 3
    1,785
    Jacksonville
    RANDY
  21. RANDY6005
    RANDY6005 Formula 3
    1,785
    Jacksonville
    RANDY
    He reversed engineered the piece , part used for Lexan door glass windows the only part no where to be found any where . Once painted could not tell them apart at all .
  22. Horsin'around
    Horsin'around Karting
    Jun 14, 2017
    169
    Where did you source the new CS lexan glass?
  23. RANDY6005
    RANDY6005 Formula 3
    1,785
    Jacksonville
    RANDY
    Eurospares from Neil, first one was used it has a few small blemishes maybe can be fix maybe or look better .
