[ATTACH]
above about being the lightest would not have typed that, but a bottle or two of wine my lips loosen up LOL . I sure there's other 360,s just as light or maybe lighter .
Challenge flamblocs are two pounds lighter than standard 360 flamblocs per corner, 8 pounds in total. Looking forward to weight it again last weight in was 2770 pounds with all stock suspension and fasteners. Image Unavailable, Please Login
If I where to go aftermarket I would buy Ohlins coil overs don't know if they have a kit for a 360 430 maybe Google it .
Even new old stock OEM control arms have some corrosion and are discolored after years on a shelf. Last set before installing I used NAPA Aluminum Brightener made them look like they were just made. Ended up remover the entire suspension back off, pulling springs off the shocks removing upper shock bushings and lower and all the control arms upper and lower steering axel hubs clean with NAPA Aluminum Brighter. Took less than one hour not bad considering not am mechanic I work in finance
Those calipers I have been on the hunt for them at a cheap price suck there so expensive. Sent from my SM-N975U using Tapatalk
Bought the axel hub above pic online off a burnt 3000 mile 2002 360 spider shipped two hundred Dollars clean up like new, also bought front upper and lower control arms two hundred.. Hell of a good deal for spares parts !!
Image Unavailable, Please Login 2002 Ferrari 360 Modena Spider Front Right Pass Knuckle Hub Wheel Spindle OEM ( This item has been shipped. Add note- 2002 Ferrari 360 Modena Spider Front Right Pass Knuckle Hub Wheel Spindle OEM ITEM PRICE: US $200.00
Image Unavailable, Please Login ITEM PRICE: US $200.00 FERRARI 360 F430 FRONT LOWER CONTROL ARM 430 Genuine OEM 192492 209168 200940
Image Unavailable, Please Login FERRARI 360 F430 FRONT UPPER CONTROL ARM 430 Genuine OEM PN: 200945 / 222500 Add note- FERRARI 360 F430 FRONT UPPER CONTROL ARM 430 Genuine OEM PN: 200945 / 222500 ITEM PRICE: US $190.00
Image Unavailable, Please Login Ferrari 430 360 Front Lower Left Wishbone Control Arm Used P/N 192492 Add note- Ferrari 430 360 Front Lower Left Wishbone Control Arm Used P/N 192492 ITEM PRICE: US $200.00 New over 900 dollars main thing to watch are burnt cars not wreck you do not want bent control arm on your 360 430
Image Unavailable, Please Login Rear Upper Control Arm & Ball Joint & Bushing 200946 OEM Ferrari 360 430 F430 Quantity: 4 Add note- Rear Upper Control Arm & Ball Joint & Bushing 200946 OEM Ferrari 360 430 F430 ITEM PRICE: US $800.00 That is two hundred per control arm ,the Challenge bushings alone 300.00 per bushing for total of eight.. 300.00 x 8 = 2400.00 they new OEM old stock. Rear new upper control arms 425.00 per arm 4X 425= 1700.00 4100.00 cost me 800.00 Hell of a good deal again !!!
Image Unavailable, Please Login New Rear Right Lower Control Arm 200941 199634 Ferrari 360 430 Add note- New Rear Right Lower Control Arm 200941 199634 Ferrari 360 430 ITEM PRICE: US $325.00 Another great buy 2006 430 Challenge rear control arm with Challenge bushings ball joint and shock bolt . Shock 170.34 control arm 452.00 two Challenge bushings 600.00 1222.34 Part No: 177664 Replaced By 204974(In Stock) New - in stockUS$170.34
