360 conversion | Page 56 | FerrariChat
360 conversion
Discussion in '360/430' started by RANDY6005, May 19, 2018.
  1. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,129
    Josh @jtcarprojects
    Looks great
  2. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Fabspeed heat shields that come with there headers had them Swain teck coated they weight just under two pounds .
    Had a set fabricated in Titanium and Swain teck coated Titanium reflects heat better than stainless .
    Saved just under a pound of weight.
  3. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  4. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Hell maybe under 2500 pounds ?
  5. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,007
    Cape Town South Afri
    Dave
    Will be very interesting to see what it comes out at .
  6. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    And what the final cost is also
    Sent from my SM-G996U1 using Tapatalk
    RANDY6005 likes this.
  7. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    Probably enough to have bought another 360
  8. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,129
    Josh @jtcarprojects
    Pur perfect in so many ways. I love that its far beyond most people could even imagine. I hope to get there soon
  9. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Yes sure I could have bought another 360 for the money I have spent on this build.
    Rather have one completely sorted and done wright that three of them IMHO.
    Thank you one hell of a complement sir !!
    Taking some time off from work next week to button up every thing and get back on the road.
  10. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    I'm dieing to hear first driving impressions.
  11. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    The ultimate suspension bushing material is a thermoplastic known as polyoxymethylene… better known as delrin. ... From the factory, classic cars were assembled using flex-prone, wear-prone rubber bushings. Some 30-50 years later, the average rubber bushing has either disintegrated or completely seized.
    Performify and clean512 like this.
  12. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Engine mounts bolts and nuts and washers 10mm x 30 in Titanium 7 ounces less than standard steel almost half a pound.
    weight for new order of Titanium bolts nuts washers over 300 pieces 1 pounds 4.2 ounces should save another 2.5 pounds.
    Getting very close getting back running just waiting for 16mm engine mounts bolts and washers and 14mm trans bolts and washers have them end of next week.
  13. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,129
    Josh @jtcarprojects
    Randy i need a spreadsheet so I can start ordering these titanium hardware. I love not having ferrari parts on my ferrari.
    armedferret and RANDY6005 like this.
  14. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Ferrari would have used Titanium on these cars if cost was not so much more than steel.
    Formula 1 cars use Titanium every where.
    Most used fasteners 6mm x 20 mm hex heads, under trays side skirts 6mm x 20 button heads and 20 mm washers.
    Studs for upper suspension control arms, oil pans and exhaust studs 8mm studs and other bits.
    clean512 likes this.
  15. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    I have a good bit of inquires from fellow Fchatters how too install ? CS rear engine bay heat shields these are pics of my factory CS heat shield how they are mounted.
    I have a set being made in Titanium for better heat reflection and a hell of allot lighter then stainless.
  16. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    You will need M5 - 0.80 x20mm long button head screws they have two center nut inserts.
  17. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Pulling valve covers repainting. new gaskets 63.58
    Pulled starter and alternator had a local shop Holts alternator go threw and check.
    starter motor contacts where on there way out replaced and clean. cost 126.00
    Alternator replaced bearing and bushing. cost 85.75
    Bought new timing belts service kit cost 416.17
    Eight new Bosh coils packs 622.00
    Two new exhaust rear lambda feller cost 255.52
    Hell after 20 plus years thinking maybe a good ideal IMHO.
    These are very reasonable prices' just have too know were to look .
    AandSC likes this.
  18. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  19. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,129
    Josh @jtcarprojects
    Looking good my friend
