360 conversion | Page 60 | FerrariChat
360 conversion
Discussion in '360/430' started by RANDY6005, May 19, 2018.
  1. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,784
    GMC evap can is a good tip. I will investigate that.
    RANDY6005 likes this.
  2. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    After a very long time looking for what I think would be the perfect fasteners for engine bay covers I choose these from ProBolt USA.
    ProBolt has the very best looking and and quality on the market hands down !! Image Unavailable, Please Login
    brogenville, clean512 and duck.co.za like this.
  3. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Using these for air box covers duel drive heads and race drilled holes drilling small holes on the air box tabs and will safety wire them they are known to vibrate lose. Image Unavailable, Please Login
    one4torque, clean512 and mwstewart like this.
  4. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    You should one less thing that can go wrong and above you can see there is allot of weight can be saved.
    The owner of the gated 360 he is a huge car guy and very very very picky about his cars he is using my 360 CS conversion as a blue print.
    I take that a huge complement he could not believe I that I was able to find a good fix for deleting evap system.
    mwstewart likes this.
  5. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Engine mount bolts had the spacer washer custom made two 16mm bolt 32.49 a piece 16mm nut 15.10 each spacers 200.00 each
    Wrap fuel tank heat shields in tunnel shield .
    armedferret likes this.
  6. Mel Spillman
    Mel Spillman Formula Junior
    733
    Sugar Land, Tx
  7. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,128
    Josh @jtcarprojects
    those are from a spider correct
  8. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,128
    Josh @jtcarprojects
    Is that the stuff From DEI
    one4torque likes this.
  9. one4torque
    one4torque F1 Veteran
    5,782
    Houston
    One4torque
    Best 360 content!
    RANDY6005 and clean512 like this.
  10. Mel Spillman
    733
    Sugar Land, Tx
    Yes, this is a spider. This is the product from DEI. Going to do the lower air intake box by the muffler next week. I'll post some pictures when done.
  11. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    This is for the gated 360 at my shop
  12. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    I sent my CS Lexan door glass to plastics4performance in the UK so they can pattern them they were happy a have them.
    In turn they are giving a front windshield & two rear quarter glass and a extra set of CS Lexan glass.
    Wend I pulled the factory CS Lexan glass from the window frames did not no the front glass was not Lexan glass but real glass ?
    Alex at Plastics4Performance said the factory CS Lexan glass was basically garbage there glass was way superior.
    They are using the factory CS pull handles should finish this week.
  13. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  14. 67bmer
    67bmer F1 Rookie
    3,119
    MD
  15. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,007
    Cape Town South Afri
    Dave
    Would be interesting to see what the ally frame detailed looked like and whether they would be possible to fabricate . I assume it's an extrusion .
    Great job Randy
  16. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Wend I get a chance takes some pics for you Duck
    duck.co.za likes this.
  17. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,950
    Weston, FL
    Scott
    Where do you buy that? I’d like to do it on my Spider too.
    Thanks.
  18. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Fitting every thing up after almost two years, the rear CS heat shields fitted perfect painting them to match airbox.
    Game changer using Tunnel heat shield fantastic stuff !! Every single new titanium torque to speck and mark with torque seal .
    Mel Spillman likes this.
  19. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Factory wraps the ac lines after twenty years they fall apart and the heat shields they use for ac compressor and alternator are a very thin piece of aluminum not very good heat shields my guess they want you to my new ones ? Remade new ac and alternators heat shields and wrap with tunnel shield and rewrap ac lines with new DEI COOL-TAPE .
  20. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
