360 conversion | Page 61 | FerrariChat
360 conversion
Discussion in '360/430' started by RANDY6005, May 19, 2018.
  1. 2008F430
    2008F430 Karting
    Apr 30, 2020
    106
    St Augustine
    Randy, when are you going to drive this masterpiece? I want to be there to see the maiden voyage.
    02360spider and RANDY6005 like this.
  2. Mel Spillman
    Mel Spillman Formula Junior
    733
    Sugar Land, Tx
    They are DEI Tunnel Heat Shields. Part # 050502 (48" x 21"). About $65 for that size. Sold through Summit Racing Supplies. Going to post some pictures of my spider. I did the ECU shields (back and front), the small heat shield in front and the air box by the rear muffler. This stuff is really nice!!
    RANDY6005 and Scott98 like this.
  3. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Very clean !!
  4. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,127
    Josh @jtcarprojects
    RANDY6005 likes this.
  5. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  6. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    maybe once done should be reliable as Toyota Camry no F1 system and engine immobilizer deleted ?
    02360spider likes this.
  7. vrsurgeon
    vrsurgeon F1 World Champ
    16,598
    Charleston, SC
    Curt
    Dude in the 11 years I've owned mine I've never had her not start with the immobilizer. It's a pain.. but it's not unreliable. Just sayin'
    Jackson32 and RANDY6005 like this.
  8. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    Happens to me i hate it
    Sent from my SM-G996U1 using Tapatalk
  9. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    I've repaired or helped with about 50 cars from immo faults which may sound like a lot but isn't. Why ? Well consider that they are 20 years old now and there are roughly 20,000 cars more or less out there, that's a pretty good failure record. My current estimate is that it's less than 1%.
    I'm sure others have sought alternative replacements too but I'm sure it's still no more than about 1% failure rate so far. Most of the time when I see a failed one it's due to someone stressing the protection components by having done a jump start.
    We cannot be too smug however as they are getting more common to fail as the years click by but at least I've got a low cost option figured out if people need to delete them. My own personal cars immobilizer failed for example.
    The biggest issue I see is as these units get older they soldered on relays will begin to fail which could dramatically increase that current failure rate and also the power supply voltage regulator capacitors, most I've seen failed are a combination of either fault or both. The worst problem is the damage they can do when they do fail. Voltage spikes can be evil and wreck havoc on other systems like the instrument cluster and more. If your immobilizer fails you also need new engine ignition ECUs if you go the Main dealer route which works out into the thousands as they only sell them in pairs too but don't worry I can virgin them too so there really isn't a big problem to buy a new immobilizer if that's what you want.
  10. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    I never had a starting issue either that aside engine immobilizer SUCKS !! LOL
  11. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,784
    It's one of those things that isn't a consideration until it happens, and when it does, it is sod's law that it happens in the most inconvenient place or time imaginable. It's great that we have people like 360Trev to provide a solution.
    patina and RANDY6005 like this.
  12. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  13. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    We'll cut out the slider holes and then get to work on making a system that closes flush like the OEM kit, utilising our pro slider system.
    It'll be a hybrid of OEM CS handles with some of the processes we use to make the F40 sliders and some of our WRC slider
    Best wishes
    Email from Plastics4Performance
  14. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Fitting CS pulls to there sliders @ Plastics4Performance
  15. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Now just waiting on Lexan CS replacement glass for the doors and two quarter rear Lexan glass and front Lexan windshield, and then putting her on a set of scales guessing real close to 2500 pounds ?? I hope
    clean512 and Performify like this.
  16. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,127
    Josh @jtcarprojects
    I would love to have it at 2500 lbs
  17. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Hi Randy.
    We're going a step further with this project.
    Our engineer is making custom slider rails that replicate the OEM Ferrari system, uses some of our WRC and F40 springs and will utilize the original handles:
    brogenville likes this.
  18. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Gated shift conversation very soon !! missing one piece missing !!
    Performify likes this.
