360 Coolant found in Spark Plug Ope | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by FerrariDublin, Jul 12, 2011.
  1. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    Haha Bob! LOL and still chuckling as I type! I'm acutely aware of that and was wondering when it might come up!
    Hi Tom, good to "meet" a fellow Dub here. Thanks for your input - first Ferrari owner posting a positive from their personal experience I think.
    Don't suppose you're an "Octane"(.ie) guy are you?
    FBB, I appreciate your wisdom and I know you're coming from a position of experience. If I do go the stop-leak route I'll be taking steps to ensure that the problem is from waterway to external only. I certainly don't need to buy trouble and welcome your input in terms of ensuring that my cylinder(s) are not effected. I don't have leakdown equipment at my disposal but I do have a compression gauge. I've never used it on this car as I'm not sure how to isolate the ignition and fuel and would be concerned about turning over the engine repeatedly without first disabling those two. Any thoughts on further diagnosis?
    Steve, thanks for your input. The chap I was speaking with today works on 360s, 430s 458s, GT3s and F1 engines. I guess he knows his stuff. They had a contract not so long ago to overhaul a number of 360 engines all with 100k+ miles on them and came across every conceivable weakness in the process. That said, as someone working in a specialised engineering workshop, I guess it comes as no surprise that his natural inclination is to recommend repair involving machining out the old liner and then re-lining with new. He has all the necessary equipment at his disposal and can manufacture a new liner also.
    One of the issues facing me is that with an engine of this age and mileage (50K) where do you stop once you start? I can't help feeling it could be like peeling an onion if I take that head off!
    So, in summary, I'm still contemplating the options and I'm keen to diagnose for sure that the problem is not effecting the combustion side.
  2. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    The difference here may not be so much as philosophy as budget.
    Good can of stop-leak for small crack, which it certainly is if there's not water squirting out from under the coilpack when the motor gets warm. $10
    Complete head-off repair. $10,000
    Try the stopleak. You'll know quickly if it's working. If it doesn't, then become an unlimited-budget guy. Do it in private. Don't tell anybody you're going to, because as you can see, there's a big market for second-guessers and I-told-you-so's anxious to spend your money.
    Spending big money just to maybe not ruin a cat doesn't make sense to me. Washed cylinder walls won't happen in the time it takes to see if the stop-leak works. You'll know if you're still losing coolant. You have enough first-hand experience of success to know, and only supposition of possible problems.
    Be brave. Be cheap. Be a stooge.
  3. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Proud words to live by!!!
  4. FerrariDublin
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    #29 FerrariDublin, Jul 17, 2011
    Well, for better or worse, richer or poorer, I've done the dirty deed and thrown a bottle of Novastop Radiator into the cooling system.
    It was recommended by my local motor factors as a very effective product and one which has no negative side-effects as far as they were aware.
    http://www.novatio.com/content/media/pdf_tech/en/740103000-PI-Novastop%20Radiator-EN-080602%20-%202.pdf
    The product is very similar to that recommended by Pap - has a metal flake granular thing going on.
    Before application I'd spent some time carefully cleaning out the effected spark plug hole, and had thoroughly cleaned and dried the #8 plug and coil. I'd taken the car for a drive with the expansion cap on loosely so the system wouldn't come up to full pressure. The car was running fine, no miss and there wasn't any evident leaking of coolant. Reasonably satisfied that there weren't any combustion issues I decided to proceed with the application.
    Followed the instructions, applied the product yesterday and haven't seen any fluid leaking since. It seems to have stopped it dead, at least for now. Temperature readings are absolutely normal. I pumped the system to 15lbs psi and left overnight. Previously this had caused the entire spark plug void to completely fill with coolant - there wasn't a drop to be seen there this morning.
    I'm not absolutely certain that the coolant levels are rock solid. The level in the reservoir does seem to have been falling a few mm bit each time I measure but I'm conscious that this may be down to a certain amount of air having entered the system and slowly being purged so I'll be monitoring carefully and will report again in a few days time.
    Once again, many thanks to all the contributors. As ever here on F-Chat there was a diversity of opinion. I appreciate everyone's individual point of view but ultimately I had to make my own decision based on the advice given and my own research versus contemplation of pulling the engine apart, likely at considerable expense and time off the road.
    Hopefully it works out but if it doesn't I'll let you all know!
  5. PAP 348
    Dec 10, 2005
    100,249
    Mount Isa, Australia
    Pap
    Nice work, keep us updated if the problem arises again. :):)
  6. FerrariDublin
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    Well, 10 days and circa 200 miles later and all remains well. Notwithstanding the low mileage the car has been driven every other day and coolant temp has been up to 100c many, many times.
    No leaks, no loss of fluid, no temperature level problems. Fingers crossed..............
  7. tomoshea
    tomoshea Formula Junior
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    Yes fingers crossed....hope it works as well as mine did.
  8. PAP 348
    Dec 10, 2005
    100,249
    Pap
    Great to hear. The best $50 you ever spent. ;);)
  9. plugzit
    plugzit F1 Veteran
    7,811
    Redondo Beach, CA
    Bruce Bogart
    So....what are ya gonna do with the ten or twenty grand you saved???? :)
  10. PAP 348
    Dec 10, 2005
    100,249
    Pap
    Coke and hookers? :D:D
  11. FerrariDublin
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    Haha! You guys are "crack"ing me up!
  12. PAP 348
    Dec 10, 2005
    100,249
    Pap
    **Groan** :p:p
  13. Frari
    Frari Formula 3
    Nov 5, 2003
    1,194
    brisbane australia
    tony
    Great Thread, good to hear all is well again, what a weird thing to have happen.
  14. Flatlander
    Flatlander Karting
    Aug 21, 2008
    92
    Middle of nowhere.
    Rich Struck
    #39 Flatlander, Aug 3, 2011
    I had to laugh a bit because I've had many, many cars that ran not only on hope but duct tape, bungee cords, stop-leak, JB Weld, and of course countless hose clamps - you can fix almost anything with enough hose clamps.
  15. Mr. V
    Mr. V Formula 3
    Oct 23, 2004
    1,247
    Portland, Oregon
    You might pause to reflect as whether this might not be an opportune time to sell the flawed beast.
  16. FerrariDublin
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    #41 FerrariDublin, Aug 3, 2011
    No way, she's stronger and better than ever now! New tyres went on today, track oriented alignment coming up next, all is well...... for the moment.
    Incidentally, having topped off the coolant five days ago to 40mm below the neck and with 300 miles up since I am happy to advise that the level when checked today was precisely 40mm below the neck. Ever since I've owned the car I've always found that whenever I topped off to the correct level that the system would quickly loose about 15mm and then sit, so the "juice" seems to have found whatever other leak there was and plugged that too. Temperatures remain perfectly normal also.
    Early days I know, but I'm feeling reasonably confident about this now.
    Thanks again to all the contributors here. I was pretty shook when I found this problem but thankfully y'all came to the rescue.
  17. PAP 348
    Dec 10, 2005
    100,249
    Pap
    Im pretty confident it's all sorted now too mate! Happy motoring my friend. :)
  18. Vettman 1
    Vettman 1 Rookie
    Jun 20, 2004
    16
    Ca. Sierra Foothills
    Rich
    Reading this thread reminded me of the early 60's. I was in the USAF and had been given a car by a fellow airman. I think it was a '41 chevy. with a cracked block or head. Never figured out which. Someone suggested pouring a bottle of "water glass" into the radiator. I'd never heard of it but drugstores sold it (cheap). It worked like a charm and I drove that car for at least another two years, problem free.
  19. Adamwii
    Adamwii Rookie
    Mar 16, 2014
    1
    I'm getting the same problem, also noticed coolant in my oil, any suggestions ???????
  20. bmw tuning
    bmw tuning Karting
    Apr 27, 2012
    178
    Portland OR
    Donny
    Coolant in oil is almost a sure sign of headgasket.... sorry. Sometimes these stop leaks can work for headgasket but on a car this caliber I would bite the bullet and fix it right. Hopefully you don't have a crack any where like OP and just a gasket change is a reasonable affair for a decent home mechanic! GL
  21. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Coolant in oil is just as likely caused by a cracked cylinder or head. Further testing is recommended.
  22. FerrariDublin
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    Adam, I presume you're talking about having coolant in the engine oil (and not the transmission oil)?
    I guess that if you have coolant in the ope for the spark plug you must have the same issue I had, but compounded by some other problem.
    I'm sorry but I can't really offer any suggestions as regards the cause.
    If you feel the leak is relatively minor, and at your own discretion, you might like to try something like I did. Mine has held up fine ever since.
    Bar's Leaks HG-1 Head Gasket and Cooling Sealant - 33.8 oz. : Amazon.com : Automotive
