360 dash lights | Page 2 | FerrariChat
360 dash lights
Discussion in 'Technical Q&A' started by witkop69, Sep 20, 2017.
  1. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,883
    Memphis, TN
    I'll take one if you want to do a group buy. My dash lights are out as well. Took me months to realize it as I rarely drive at night. I'd like to fix it though.
  2. jlf45
    jlf45 Rookie
    Oct 26, 2006
    3
    Carbondale IL
    John L Foster
    Thank you for the response Stammler. Yes I did get a replacement panel from EL Panel & Tape and it was in the 3 hour range to install including time to remove and replace the instrument panel from the car. All in all not a bad job. But still no back light. So I now suspect the DC AC inverter is the problem.
    Several sources popped up on Google for a replacement inverter, but I have not tried to order. Minimum order of 10 as noted above is not encouraging. Also note Eric 355 comment about probably several transistors have failed as well.
  3. RedNeck
    RedNeck F1 World Champ
    12,475
    The CSA
    Me
    If a few more people jump in, I'd be for it.
  4. imahorse
    imahorse F1 Rookie
    4,478
    WI
    Dustin
    I'm down
    Sent from my SM-N950U using Tapatalk
  5. RedNeck
    12,475
    The CSA
    Me
    I already owe you one....actually my lazy, procrastinating ass has a few things I need to send you. Did you get an address change?
  6. BenjaminLeger
    BenjaminLeger Rookie
    Nov 10, 2020
    2
    Hi guys,
    I red this thread with interest from scratch because I'm facing the same back light problems... seems to be pretty commun... I would like to check the 2 transistors but I cant read anything on them. Could anybody tell me the reference of these transistors?
    From the other hand, @RedNeck , I might be interested in buying one of your transformers if you still have one.
    Thank's for helping
  7. RedNeck
    12,475
    The CSA
    Me
    I can make sure they are still available then put the order in this week if yall want them. Imagine after all is said and done (having them shipped to me then shipping them out to y'all) it would probably be around $40/piece I'd imagine if they are all going stateside, but I'll get back with the actual cost. I'm not making $$, not interested, just getting rid of the surplus.
  8. BenjaminLeger
    Nov 10, 2020
    2
    I would prefer being sure about the transistors bifore replacing the transformer. Could you tell me what is whiten oàn them?
  9. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    922
    Georgia
    Mark Gronsbell
    I would be in for the purchase of a transformer. Thanks
  10. eric355
    eric355 Formula 3
    1,235
    Toulouse (France)
    Eric DECOUX
    They are NPN transistors. You can check them with a DVM.
  11. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Do you have the number of those transistors, Eric?
  12. DanNE
    DanNE Formula Junior
    Jun 7, 2013
    719
    Guys any update on this? Tonight I drove the car at night for the first time in a while and after the first ~10 minutes the dash lights turned all off (but the needles were still illuminated as others here have experienced) and then after an hour or so they came back on by themselves.
    It was not the brightness level and I did not fiddle with them at all...
    Any way to debug what the problem is?
    Thank you all!
  13. eric355
    eric355 Formula 3
    1,235
    Toulouse (France)
    Eric DECOUX
    Most probable root cause is the electroluminescent film which is dying. This is the first thing to check.
    Sometimes, transistors and transformer can be destroyed when the film is failing in short circuit.
  14. DanNE
    Jun 7, 2013
    719
    @eric355 do you fix these or can you recommend where to get the electro film? I'm pretty good with the electronics so that would not worry me.
  15. eric355
    eric355 Formula 3
    1,235
    Toulouse (France)
    Eric DECOUX
    hessank and Qavion like this.
  16. 24000rpm
    24000rpm F1 Rookie
  17. eric355
    eric355 Formula 3
    1,235
    Toulouse (France)
    Eric DECOUX
    Sorry guys, I have only 1 spare that I will keep for personnel use as long as I have the 360 ... just in case !
    Don't know where to find them now ... may be the companies which repair these clusters have some stock but they probably won't be willing to sell them.
    Alternatives are to bypass the DC/AC inverter on the PCB and to replace it by a small independent one (a few $ on ebay), or to dismantle such an independent DC/AC inverter to use its transfomer ...
  18. 24000rpm
    24000rpm F1 Rookie
    how to determine which indenependant one is fit to use?
    Mimmo Blue likes this.
  19. 24000rpm
    24000rpm F1 Rookie
    Pouvez-vous me dire le contact de "Yinan", Je suis en Chine, et je peux leur parler
  20. 24000rpm
    24000rpm F1 Rookie
    imahorse likes this.
  21. 24000rpm
    24000rpm F1 Rookie
    robertjskelton and Qavion like this.
  22. RedNeck
    12,475
    The CSA
    Me
    Ha! They should add that to the datasheet :D
    Since this thread resurfaced, just to let everyone know what happened with the broker, is that they kept changing the minimum on me and giving me the runaround when they actually replied to my emails so it made it impossible to make it work. I'll try emailing them again to see if they even have any left and if they are still willing to work with me. If they will honor their original deal I will just buy them and sell the extras in the classifieds at cost. Brokers are a pain in the ass.
    mb5, hessank, imahorse and 1 other person like this.
  23. 24000rpm
    24000rpm F1 Rookie
    Qavion likes this.
  24. Qavion
    Qavion F1 World Champ
    14,533
    Ian Riddell
    Would you be able to get some resistance readings on the good ones?
    Is there any numbering on the pins or did you just choose some random numbers?
    I don't know if it's a step up transformer or a step down in that particular circuit. I just assumed the secondary coils had the higher resistance (like a spark plug coil). Of course, the tap on pin 5 may not be in the middle of the primary coil.
  25. 24000rpm
    24000rpm F1 Rookie
    don't have my multimeter now, will do that in a few hours.
    Numbering are random, but there's a bird crap on it, maybe it mean #1?
    Question, aren't the coils shares the same iron core?
    why on your diagram, the coils are seperated?
