360 dash lights | Page 3 | FerrariChat
360 dash lights
Discussion in 'Technical Q&A' started by witkop69, Sep 20, 2017.
  1. Qavion
    Qavion F1 World Champ
    14,526
    Ian Riddell
    Thanks!
    It's just the way iron core transformers are drawn in standard wiring diagrams. There are a number of symbol variations, but I've long since forgotten my basic electronic training.
  2. 24000rpm
    24000rpm F1 Rookie
    on the spec sheet, it says input 0.25v, so surely its a stepup transformer?
  3. 24000rpm
    24000rpm F1 Rookie
    almost missed this datasheet that came with the package.
    so, the bird white crap is PID #1 as stated in this sheet in Chinese.
    And what is this 13.36, 13.43 , 12.29 13.41 mean?????
  4. Qavion
    14,526
    Ian Riddell
    These are inductance values rather than ohms. mH = millihenry There are various definitions for inductance. It can be described as a resistance to a varying current rather than a DC current. The frequency of the AC current is specified as 1kiloHertz in your document.
    Unfortunately, I can’t make any sense of those values you provided. I don’t know if the coil setup is as we have shown it. I was expecting 4~6 to be close to the sum of 4~5 and 5~6 if pin 5 was a tapping on the coil.
  5. 24000rpm
    24000rpm F1 Rookie
    I dont think it is very difficult to decipher.
    4-6 is one single coil that is maybe 60x more than coil 1-3 in length. ( or 10x more and 6x less in cross section area)
    pin 5 is just a touch that is very close to the end of the long 4-6 coil.
    Qavion likes this.
  6. Qavion
    14,526
    Ian Riddell
    My mistake... I was misreading the values.
    So the good one should look something like this
  7. 24000rpm
    24000rpm F1 Rookie
    if you think 657 ohm side as primary, that means this is a step down transformer?
  8. Qavion
    14,526
    Ian Riddell
    If I said one way or another, it would only be an un-educated guess or lots of "assuming" ;) I don't know what the function of the transformer is or which is the input. I'll remove the primary/secondary labelling to be safe.
  9. 24000rpm
    24000rpm F1 Rookie
    it is , i heard, to power up an EL panel, which illuminate the instrument cluster.
    never thought EL panel uses ac instead of dc.
  10. Qavion
    14,526
    Ian Riddell
    Sounds familiar. Doesn't the EL panel use relatively high voltages?
    (EDIT: Found this... but to be confirmed)
    https://www.ferrarichat.com/forum/posts/145085245/
  11. eric355
    eric355 Formula 3
    1,235
    Toulouse (France)
    Eric DECOUX
    Yes it does. It needs high voltage AC supply
    I have measured up to 250Vpp (depending on illumination level) and a frequency in the 400-500Hz range.
    Qavion likes this.
  12. 24000rpm
    24000rpm F1 Rookie
    so the 647 ohm side is the secondary coil , correct?
  13. eric355
    eric355 Formula 3
    1,235
    Toulouse (France)
    Eric DECOUX
    Yes, correct.
    24000rpm likes this.
  14. 360chrisT
    360chrisT Rookie
    Jul 5, 2022
    39
    Grimsby, UK
    Chris Thompson
    Where did you get them from, I would like to purchase one if possible. Thanks
  15. 24000rpm
    24000rpm F1 Rookie
    Le Contact Est
    Lun Lee
    INAMI Enterprises Co., Ltd.
    Tél: +886-7-6221201
    e Contact Est
    Lun Lee
    Tél: +886-7-6221201
  16. Qavion
    14,526
    Ian Riddell
    Is it clear from the circuit board mounting, which terminals of the transformer are used? It may only need one pair on either side.
  17. 24000rpm
    24000rpm F1 Rookie
    its not clear... frankly, i messed up....
  18. eric355
    eric355 Formula 3
    1,235
    Toulouse (France)
    Eric DECOUX
    All 6 pins are used.
    Qavion likes this.
  19. imahorse
    imahorse F1 Rookie
    4,478
    WI
    Dustin
    Do you know the number or specs on the transistors offhand?
    Sent from my toilet using FerrariChat.com mobile app
  20. imahorse
    imahorse F1 Rookie
    4,478
    WI
    Dustin
    Qavion likes this.
  21. Mimmo Blue
    Mimmo Blue Formula Junior
    Apr 17, 2018
    325
    Stoney Creek, Ontario, Canada
    Dom
  22. imahorse
    imahorse F1 Rookie
    4,478
    WI
    Dustin
    Overseas. It was a colossal pita and months long process. Unfortunately almost all of them are spoken for.
    robertjskelton likes this.
