360 Data Acquisition | FerrariChat
Discussion in '360/430' started by WCH, Nov 2, 2003.
  1. WCH
    WCH F1 Veteran
    Mar 16, 2003
    5,180
    Started this on the old Board - asked whether basic data (throttle position, steering wheel position, lat gs, long gs, temps, etc) could be downloaded from the 360 series cars, in particular the Challenge cars - sufficient to draw a track map and monitor temps, for example. TimG replied that this could be done, and I wanted to ask whether anyone has done this? Does Ferrari sell software and cables, or do you need the SD2? Thanks, Will
  2. fatbillybob
    Aug 10, 2002
    25,697
    socal
    DL20 datalogger. its been done. do a google search the company will pop-up
    WCH likes this.
  3. WCH
    WCH F1 Veteran
    Mar 16, 2003
    5,180
    Thanks!
  4. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,823
    Jupiter, FL
    Paul Bianco
    interested in hearing more.
  5. Brian C. Stradale
    Brian C. Stradale F1 Rookie
    Mar 17, 2002
    3,603
    Dallas, TX, USA
    Likewise... is anyone using a DL20 or a DL90 for data acquisition with a 360? What data are you able to record? What analyses have you found most useful?
  6. FLATOUTRACING
    FLATOUTRACING F1 Rookie
    Aug 20, 2001
    2,684
    East Coast
    Jon K.
    Will,
    In referrence to our previsous discussion on the old board about your oversteer problems and loosening your front lug bolts to eliminate the oversteer.
    I may have given you a "half-measure". Just take the bolts off completely and that should solve the oversteer problem (and my keeping up problem as well) .
    All kidding aside, I'll be interested to see you logging system and how much setup info you can get from the car.
    Regards,
    Jon P. Kofod
    1995 F355 Challenge #23
    www.flatoutracing.net
  7. WCH
    WCH F1 Veteran
    Mar 16, 2003
    5,180
    Jon - always appreciate your help, but next time I think I'm going to try my idea of carrying huge entry speed to really get the aero working.
    Any more news on the new car? [Edit - just checked the flatout website, your 2004 plans sound great, car sounds great, I'm jealous.]
    Brian - I did the suggested google search and found the DL 90, was going to contact the manufacturer to see if they had any experience with this application. I probably should contact FoW first to see what they suggest, feel like I'm going to be reinventing a wheel that doesn't need to be reinvented.
  8. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,237
    Austin, TX
    Randy
    Not a 360 application here, but we've used the DL90 on a supercharged S2000 track car (stripped, gutted, approx. 2350#'s). works rather well. we didn't have throttle positions hooked up, but you can see all the g's, track map, lines that you took, etc. It is quite a useful tool to learn from and to see how you can improve by studying the lines and the way you are moving along the track. Definately worth the investment if it will plug in easily in the 360. Only downside - the DL90 is linked via serial connection, so the downloads are awfully slow. The ohter bit is the GPS receiver which we placed up on the hood, strung from underneath. Works well and will cause minimal drag. It will fit in your palm to a little larger if memory serves correctly.
