360 engine in 348? | Page 4 | FerrariChat
360 engine in 348?
Discussion in '348/355' started by Bird511, May 20, 2023.
  1. carnutdallas
    carnutdallas Formula 3
    1,978
    Dallas Burbs
    Rob
    Been a journey. Hope you have some more pics coming soon. Mad Props to making it happen. Love the idea of upgrading. Cheers to you.
  2. Bird511
    Bird511 Karting
    Aug 10, 2022
    72
    Brooksville Florida
    Michael Bird
    Figured I should post an update, I have put a couple thousand trouble free miles on it at this point. So to sum it up 355 engine, 355 6 speed, 355 rear craddle so all 355 rear suspension. I'm running a Haltech R3 standalone ecu which is also a power control module so I've slowly been running more and more of the vehicle functions off the ecu, eventually probably going to just eliminate all of the factory 348 wiring and have everything run through the ecu.
  3. ChoonHound
    ChoonHound Formula 3
    2,275
    Saint Michaels, MD
    Lucas
    “It’s not all talk with him”. - Carlo Gervasi
    bravo dude.
  4. Bird511
    Bird511 Karting
    Aug 10, 2022
    72
    Brooksville Florida
    Michael Bird
    I know it's rare these days haha, but I typically do what I say I'm going to do. Financially I probably should have just fixed my stock engine or put another in, but it's definitely faster, makes better noises, and it's nice having an electronics system that isn't temperamental and ancient.
    MacNugget and ChoonHound like this.
  5. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,852
    Lake Villa IL
    Have to say I think you made a great decision. Nice work!
    I'm curious if you have ran it on a dyno? I've been modifying my car as well and had some thoughts about shorter/straighter inlet stacks.
    Or, do you see any drop in map kpa as rpm increases to redline on a data log? At least then could know if the throttle body/blade size is a restriction or not. Especially on this setup with open/short/straight inlets.
  6. vjlax18
    vjlax18 Formula Junior
    687
    Nottingham, MD
    Please share details of the stand alone process. The 348 drivetrain is pretty solid, it's usually an electronics issue with our cars and a stand-alone ECU could drastically change everything.
  7. Bird511
    Bird511 Karting
    Aug 10, 2022
    72
    Brooksville Florida
    Michael Bird
    I havent put it on a dyno yet, I do actually have a couple different sets of velocity stacks and do plan on trying different sets to see what affects it has. Unfortunately it's a bit of an odd size for velocity stacks however so there isn't a very big selection and nothing really that goes on without some sort of modifications, my neighbor has a cnc lathe and is eventually going to make me some 1 off ones.
    INTMD8 likes this.
  8. Bird511
    Bird511 Karting
    Aug 10, 2022
    72
    Brooksville Florida
    Michael Bird
    Just have to build an engine harness and figure out sensor compatibilities and such then obviously figure out what the pinouts are for the car chassis plugs. I have built alot of engine harnesses over the years for myself and customers when I worked on cars for a living. My car works like factory with all factory gauges working.
    RC2211 likes this.
  9. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,852
    Lake Villa IL
    Maybe you could have them printed. I think that's how places like carbon-smith do it but not sure.
