News
360 Exhaust Valve Question
Discussion in '360/430' started by spider348, Aug 30, 2019.
  1. spider348
    spider348 Formula 3
    1,169
    MA
    Replaced my Tubi on my 360 spider with the modified 430 exhaust as detailed by Aldous Voice(Great Reference website). Very close to Challenge Stradale System.
    Started 360, very loud! Bumper not on to allow check for leaks. Both Bypass Valves were open at idle.(They were capped prior).
    Selenoids appear to be connected OK.
    System ECU should control open operation at a specified point based on programmed data from my understanding.
    I appear to be missing something!
    Input appreciated.
  3. spider348
    spider348 Formula 3
    1,169
    MA
    Sorry all. Came from a 355 where the bypass valve is closed until vacuum applied. A search on the forum shows the 360 and 430 are the opposite. Open until vacuum closes the valve. At start loud until vacuum closes the valves.
    ECU regulates vacuum level I assume.
    My understanding correct?
    I'm 360 Canuck likes this.
  4. bisel
    bisel Formula 3
    Sep 12, 2012
    1,225
    Scottsdale, Arizona
    Steve Bisel
    That is pretty much correct
  5. spider348
    spider348 Formula 3
    1,169
    MA
    Thank You!
    Just need to verify the valves are adjusted properly. Install bumper and drive!
